Stutter with too much movement, convert Hi8 in VirtualDub?
I started using Virtualdub to convert my super 8 tapes to my laptop.
The following only occurs when I try to convert home made videos (captured with a Panasonic Viewcam VL-H860). When the camera moves fast (for example when panning fast to the left) the image begins to stutter when I capture it in Virtualdub. But this does not happen when I hook the camcorder to my tv. Does anybody know what I can do? I've uploaded a video to show the effect https://www.youtube.com/watch?v=w_gX...ature=youtu.be . I am from Holland so I am using Pal-b with 25 fps. I have a video grabber from Magix. Computer info: Samsung laptop, Quad-core processor (up to 1.4 GHz, 4Gb RAM, 64 bits, x86, Windows 10 Thanks! |
There are no "super 8 tapes". Sony had Video8, Hi8, and Digital8 (and the last is just DV on 8mm).
Although Youtube is usually useless for sample (because it re-encodes), this is an obvious error. In almost all cases, a "stutter" issue is due to bad/wrong framerate and/or interlace choices. Dropped frames is another potential. You have a camera/player issues, made worse by lack of TBC, made worse yet again by the cheap Magix card. |
