12-19-2017, 02:13 AM
jeffpeck jeffpeck is offline
Here is a video that I transferred from an old VHS tape from a Sharp DV-RW550, using a Diamond Video Capture device on a MacBook Pro:
https://www.youtube.com/watch?v=CGsW...ature=youtu.be
I have many old VHS tapes (mostly recorded on family camcorder) and they seem to have that same issue.
Will a TBC-1000 fix this?
Will upgrading to a better VCR fix this?
Is it simply a matter of cleaning the VCR's head? Adjusting tracking?
Before I invest in this endeavor, I'd like to know the correct tool to solve this particular issue.
Some googling seems to indicate that a Panasonic ES-10 might solve this problem. Will an ES-10 also satisfy the need for a TBC? Are they the same thing (when the ES-10 is used as a passthru device)?
File Type: jpg Screen Shot 2017-12-19 at 3.12.20 AM.jpg (36.5 KB, 48 downloads)
12-19-2017, 10:40 AM
You have more than just tearing going on. There are obvious timing issues all over the image. You can easily see the wiggling letters, the shaking box, etc. A better VCR will likely fix it, yes.
However, if the tearing is too significant, only an ES10/15 will work.
Note: Realize that "significant" is not something you can see. A tearing error can appear tiny, yet even an ES10 can sometimes fail to correct too much signal damage.
You should start with a better VCR. Odds are, yes, it fixes your issue.
(PM me, I still have a good model JVC Pro available. I'm also about to let go of a Panasonic AG-1980, and for best results it needs to be paired with green AVT-8710 that I'm letting go with it. That latter one would probably work best for you.)
TBC-1000 will only correct the signal, not anything visual. Do note, however, that a capture card almost always balks at impure signals. That's why any good workflow is S-VHS VCR with internal TBC (clean image) > external TBC (clean signal) > and then the good capture card that retain all the detail and signal quality of the tape (ie, not a cheapo EZcap/EZcrap).
You can't clean your current VCR for this. That will do nothing.
An ES10/15 is NOT a TBC, and will fail to correct some of the same issues found in true TBCs. The bigger issues is the ES10/15 has side effects, that will degrade your image. It is something to use only when all other methods of truly fixing it have failed. The ES10 is a tradeoff. You lose tearing/unstable, but gain issues in color, posterization/ghosting, etc.
vhs tearing
Using TBC and video still tearing? jriker1 Restore, Filter, Improve Quality 127 10-06-2016 11:41 AM
New flagging/tearing VHS fix without DNR! premiumcapture Capture, Record, Transfer 4 04-26-2015 11:45 PM
Top Screen Tearing/Distortion GreenAcres Capture, Record, Transfer 6 02-15-2014 01:29 PM
Screen protectors for matte screen LCD on Macbook pro laptop? Sossity Computers 1 12-09-2010 07:01 PM
VHS tearing - hardware to fix it? admin Restore, Filter, Improve Quality 2 10-01-2009 05:30 AM
