Macrosystems AVIO better than DVD recorder?
I'm testing different kinds of equipment for capturing and stumpled upon this:
http://www.macrosystem.be/nl/product...ioclassic.html Dedicated video editing system, can be had for little money, I read the quality should be good, but no one tells me what quality the captured files are. I dont want to use the system for editing, just capturing. The source is a JVC SVHS S8500 recorder. I read elsewere that some bitrates Mpeg2 is quite good, but no idea if this device supports that. For those who do not know the system: some info: Quote:
http://www.digitalfaq.com/forum/imag...avio_blk-1.jpg |
That's not something I'd ever mess with. Quality is surely lower than anything available in standard computer workflow, and more finicky than normal DVD recorder. It's clearly proprietary hardware, probably with no fix available if something go wrong. Maybe if it was under $100, and I was in an adventuresome video mood.
So are you looking at one? Or do you actually have one in-hand to test out? |
Can buy one for 35 euro. Dont have it
