02-14-2018, 03:33 PM
JoRodd JoRodd is offline
I am trying to capture video from a Beta to my computer using VirtualDub (huffyuv) via ATI TV Wonder HD 600 USB.
I have not had issues before but now I get this message after capturing for approximately 20 minutes.
02-15-2018, 02:32 AM
Jtm732 Jtm732 is offline
Hello,
Have you tried using the non-mulithreaded version of HuffYUV? Personally I would avoid using the MT version due to compatibility issues as it is seen as distinctly different than the much more common non-MT version.
As far as the debug information, it is related to a function attempting to access a memory address it has no business accessing (possibly a memory leak caused by the multithreaded code improperly handling memory management). This also seems to be connected to your video driver failing with a direct draw call.
The following users thank Jtm732 for this useful post: JoRodd (02-27-2018)
02-15-2018, 04:27 AM
And many posts here have warned people about the finicky AIW HD 600, which isn't the same thing as the ATI 600 USB. Also , you should specify what operating system and what version of VirtualDub you're using.
02-15-2018, 05:53 PM
Thanks for the replies. I am using Windows 7 64 and VirtualDub 1.9.11.
I have used this for many months without issue.
02-15-2018, 11:52 PM
Do you have any crashes while intensively using your video card to do other tasks (i.e. play video games)? What temperatures are your computer's components running at?
02-25-2018, 05:34 PM
My computer's temperature is fine.
What is strange is that I have used this without issues for the better part of a year.
I tried again after reinstalling the ATI drivers and got the error.
I have attached the screenshot and the crash information.
02-25-2018, 05:41 PM
Why are you using Huffyuv-MT? That's probably the issue.
Did you try it with non-MT Huffyuv yet?
The following users thank lordsmurf for this useful post: JoRodd (02-27-2018)
02-25-2018, 07:49 PM
Downloaded, extracted but was unable to install. Received this error.
Followed instructions on this page: http://www.digitalfaq.com/forum/vide...l-huffyuv.html
I am running Windows 7 64.
02-26-2018, 10:26 PM
Correction. It worked. I entered the wrong path.
Thanks for all the replies.
02-27-2018, 12:19 AM
Sometimes a simple correction is what it takes. I've done worse. Glad you worked it out.
The following users thank sanlyn for this useful post: JoRodd (02-27-2018)
Capture VHS from USB to VirtualDub - then computer crashes? Koen Capture, Record, Transfer 12 06-02-2015 09:56 AM
Interesting blank disc failure NJRoadfan Blank Media 5 11-13-2013 11:26 PM
What is the Best Screen Capture Program? bigk181 Computers 5 10-08-2012 07:04 AM
Capture closed caption (CC) in ATSC program? jmac698 Capture, Record, Transfer 1 02-06-2011 01:09 PM
Capture Card Program for Recording Shows JonathanEntertainment Capture, Record, Transfer 3 03-22-2008 03:07 AM
