CPU usage in virtualdub
Hi,
I am doing satellite capture via hdmi and a capture box through virtualdub. Is the CPU usage something of concern? The reason I ask is if I use huffyuv codec it says CPU usage around 100%, if I switch to a UT lossless codec it says around 200%. There are no dropped frames with either. Processor: 2.4GHz Intel Core i7-5500U dual-core, 4MB cache 5th gen. thanks |
