Quantcast What causes this wobbly lines? - digitalFAQ Forum
08-02-2018, 11:43 PM
ragu0012 ragu0012 is offline
This is a Maxell 8mm tape shot in 2002 captured on a Sony Handycam DCR-TRV820 Digital 8 with TBC and DNR activated.. and using a datavision TBC as well.
Occasionally i will get these squiggly lines seen here in the photograph.
I have deinterlaced to get a clean screen shot but this is not caused in the deinterlace process. It's there on the capture.
I'm sure someone has seen this before. What say you? Thanks!
08-03-2018, 10:22 AM
Do I understand correctly this from a Video8 analog tape recording played on a Digital8 camcorder using capturing from the analog output of the camcorder?
Some of it looks a bit like some intermittent display of portions of prior frame/field.
Was there camera movement (e.g., zoom and/or pan & tilt) underway during this shot?
What happens if you try different combinations of DNR and TBC off?
Have you tried a capture via Firewide (iLink/IEEE1394) from the camcorder?
08-03-2018, 10:55 AM
Yes I captured with S video.
There is definitely camera movement on this part.
I havenít yet tried recapturing the same tape under different settings. Unfortunately I didnít notice it as it captured, just when I watched the capture afterwards
08-03-2018, 04:33 PM
Try capturing with different setting, and via IEE1394. See if any work better. Sometimes, but not very often, DNR and TBCs will interact to produce worse capture.
Also, are the lines consistent with repeated captures of the same segment of the video?
What capture device did you use?
08-03-2018, 06:49 PM
Was there any buzzing in the soundtrack when the glitch occurred? 8mm uses AFM audio recorded with the video heads and any tape dropouts will result in audio problems too.
08-04-2018, 10:35 AM
Those are digital camera artifacts. Very, very common. It's often a media issue, though not always. I see this a lot of DV tapes that were poorly stored, but also other formats like MicroMV.
Picture goes green and wobbly VHS tape? koberulz Restore, Filter, Improve Quality 10 02-04-2018 08:50 AM
Field repeats, tearing, wobbly lines? koberulz Restore, Filter, Improve Quality 68 09-27-2017 05:04 PM
Wobbly/Out of phase VHS audio-Caused by tension error? Belmont Capture, Record, Transfer 3 04-25-2012 06:14 PM
Remove extra lines (empty lines) from copied/pasted text with Notepad++ kpmedia Computers 1 10-07-2011 05:32 PM
Ulead DVD Workshop PSD lines lordsmurf Author, Make Menus, Slideshows, Burn 3 03-14-2009 08:45 PM
