09-22-2018, 06:10 PM
Fr4gz0n3 Fr4gz0n3 is offline
Hi everybody,
it's my first post in this very informative forum. I'm an italian A/V enthusiast and I'm collecting (
almost) all I need to capture old VHS decently.
I have a JVC HR-S7700 and an Ati 128 AIW (non PRO) with all the accessories.
The card is AGP 2x (3.3v) and I have problems to find a good AGP 2X compatible motherboard at a reasonable cost.
I've found an ATI AIW 9000 (AGP 4x) without accessories. I would like to know if the Ati 128 input adapter would work on the 9000.
Thanks for your support
09-22-2018, 06:32 PM
The pre-Radeon 128 / 128 Pro cards have slightly different mini DIN on the input cables, so no, not interchangeable. All of the Radeons, however, have the same purple/domino input cables. The Radeon are actually very easy to find, it's the 128 and 128 Pro that are much harder to locate.
The purple input block is under $10 on eBay (USA).
A good AGP 2x/4x board should be easy to find, as almost all AGP boards accept 2x AGP.
09-22-2018, 09:00 PM
I have the AIW 7500 Radeon AGP and the AIW 9600XT Radeon AGP. They have different input cables and different monitor connections. Neither set would fit the 9200.
09-23-2018, 01:53 PM
Thank you for the answers.
AFAIK only Pentium 3 and athlon xp motherboards have universal agp or agp 2x. Are these architectures enough for vhs capture?
I think that US market is a bit different than European one at least on eBay. I’ve found a aiw 128 pci without accessories for 20 euros (auction) that may can solve my problem.
Wanted: ATI AIW 9600 output adapter cable TechWizard Marketplace 3 04-28-2018 09:01 PM
JVC HRS-9000 VCR on eBay! darky8 General Discussion 1 04-04-2015 08:40 AM
AIW 9000 to capture VHS...other PC hardware? GroverXpup Capture, Record, Transfer 4 10-19-2010 12:51 AM
How to split cable TV and cable internet coax for two rooms ? stoogedog Computers 6 12-05-2006 06:15 AM
ATI 9000 Capture Artifacts inchga Capture, Record, Transfer 10 02-22-2004 01:59 AM
