11-16-2016, 11:25 PM
bilditup1 bilditup1 is offline
Hey all,
I've been using a Panasonic AG-1980 (serviced by TGP) as my main capture deck for about a year now. I was curious enough, though, to get a JVC VCR on the recommended list to see how it would perform. Unfortch it suffers from some very bad tearing and what looks like slightly blown out levels (see attached screenshots). This is with Digital TBC/NR on, Digital R3 off. Both times the video has been run through a Datavideo TBC-3000.
So. Is this fixable, or should I try to return the deck?
11-01-2018, 06:04 AM
Originally Posted by bilditup1 View Post
Hey all,
I don't know how I missed this post initially.
Thanks for the reviving it via PM.
But the answer is probably easy. I'd need to see the deck in person to give a definitive answer. But offhand, seeing and reading everything here, there's a chance that the heads are shot. I've seen something exactly like that once or twice in the past. At least once, it was definitely the heads.
If it was always like this, and it was bought from non-qualified sources (ie eBay, and likely with a "works great" condition stated), then I'd bet its a simple case of the deck having either:
(a) been "cleaned" wrong by a moron using Q-Tips, as seen on Youtube guides from equally unqualified morons -- and ironically, probably didn't need to be cleaned at all (ie, all the dumb "clean the heads" knee-jerk responses you see online, also from unqualified non-video know-nothings)
(b) just an old deck that been run into the ground, probably no maintenance ever, heads completely shot
Yes, pet peeves = eBay, cleaning heads, Q-tips. No good comes of it.
Since this is an older post, clearly too late to return.
If you still have it, maybe good for parts. Whatever you do, do not discard the unit as trash. All S-VHS decks have some value, even if not working.
Issue with newly purchased Sony DVD+R MOTO Blank Media 5 09-02-2019 06:11 PM
Using TBC and video still tearing? jriker1 Restore, Filter, Improve Quality 127 10-06-2016 11:41 AM
New flagging/tearing VHS fix without DNR! premiumcapture Capture, Record, Transfer 4 04-26-2015 11:45 PM
Capture problem with newly bought DVHS deck monks19 Capture, Record, Transfer 15 04-04-2014 04:09 PM
VHS tearing - hardware to fix it? admin Restore, Filter, Improve Quality 2 10-01-2009 05:30 AM
