Suppressing JVC video CALIBRATION message?
I'm attempting to capture an old VHS tape for a family friend with a JVC VCR. The tape has a lot of starts and stops with blank spaces between them (definitely amateur hour, here). My problem is that the JVC recorder flashes its "VIDEO CALIBRATION" message after each blank spot, and this gets annoying quick. I could edit it out after capture, true, but some of these come over Cute Kid Moments. I don't have a manual for the JVC (SR-VS30), nor do I have the remote. Is there some way to suppress this annoying message?
Don't know, if you can "bridge" the gaps with the insert recording function, without the remote.... but i guess the original recordings were not made on your vcr... Page 73 describes the function switch off http://pro.jvc.com/prof/attributes/i...l_id=MDL101333 |
If you've never gone into the menu, you should also disable R3. This is one of the few models were JVC calibration is actually helpful. Most models should have that turned off as well. The manual is here: http://pro.jvc.com/prof/attributes/i...l_id=MDL101333 But I'll also attach it here later: http://www.digitalfaq.com/forum/vcr-...r-manuals.html The official is broken into 4 parts, no sense in that. I'll re-merge for my attachment. And just FYI to other reading this: Never use the DV side. It eats tapes, defect of the model series. You get it for the S-VHS inside. Forget the DV is ever there. Whenever I sold my extras, I purposely blocked off that half of the deck, sometimes even disconnecting its power inside. I tended to customize these in several ways. Quote:
Look for the LP20337. For example: http://rover.ebay.com/rover/1/711-53...m/323506172176 Beware of stock photos!!! More are used, so inspect the auction images closely. You don't want missing covered, corroded battery slots, or just something nasty. I actually have a few new ones available, recently bought a batch of NOS from a defunct vendor. Wanted a few remotes for my better decks being sold on the marketplace. |
Site design, images and content © 2002-2022 The Digital FAQ, www.digitalFAQ.com
Forum Software by vBulletin · Copyright © 2022 Jelsoft Enterprises Ltd.
