-   -   Recording image issues VCR to laptop, Easycap? (https://www.digitalfaq.com/forum/video-capture/9194-recording-image-issues.html)
digitalize_it 11-30-2018 05:43 AM
2 Attachment(s)
Hello,
I recently started to digitalize our home videos. Next fase will be the VHS tapes.
I'm using an "EasyCAP" video grabber and i've connected it via tulip and an output scart (cable no longer than 2meters).
It connects and I'm getting image and sound but it's of very bad quality.
Attached are two image examples. The first when it's only connected. The second you can see the poor imagery.
I could not make a "printscreen". When trying the distortion lines and purple background disappeared...
I tried different tapes and already tried to fast forward and rewind the tape before recording.
Any suggestions or tips are welcome.
lordsmurf 12-09-2018 02:40 PM
EZcap/Easycap (infamously known as "easycrap") devices are known for lousy capture quality, and all sorts of various issues. Your issue may be drivers related, or the Easycap can't handle the incoming signal. Either way, the cheap card is at fault.
It doesn't help that you're using the included junk software, and not VirtualDub.
The ATI 600 USB is far better as a card.
But the VCR also matters.
Nikon 07-16-2021 11:41 AM
Helo sir
When i conect my vcr directly with LCD so all were goof but when attach vcr with oc through easycap or may also with internel capture card so colorfull horizental lines appear..plsss help.
I use sony P03 vcr..u asked that VCR ALSO MATTER
so plsss why this
