04-11-2022, 11:33 AM
jsj2251 jsj2251 is offline
hello!
Which is the best choice when capturing Hi8 tapes?
1. What is the difference between Amarec tv and Virtualdub?
2. What is the difference between HUFFYUV and Lagarith?
04-11-2022, 02:59 PM
For the software, whichever works best for your capture device and provides captures with no frame drops, with audio in sync, etc.
AmarecTV's interface is godawful, in my opinion. I like VirtualDub's interface, but I can't see it with fresh eyes since I've been using it for 20 years. Under the hood, they both use DirectShow/Windows APIs to grab video and audio from capture devices and place them into files on a storage medium. But there are a lot of little intricacies when it comes to exact device support/usage.
Lagarith is newer, provides a higher compression ratio, and I believe tends to decode faster with multi-core processors than the classic Huffyuv. Huffyuv has much lower system requirements and is much less likely to be the cause of a dropped frame.
Personally, I prefer Ut Video Codec and MagicYUV in modern times. Huffyuv and myself had a loving decade-long relationship starting in 2002, but times have changed.
The following users thank msgohan for this useful post: jsj2251 (04-12-2022), RobustReviews (04-11-2022)
04-11-2022, 03:14 PM
Vote for Lagarith here, but also I'm not one for fussing over such matters too much, both Huffyuv and Lagarith look rather great to my eyes. I've used both, but Lagarith is a better fit for us.
Amarec is certainly an acquired taste to be as polite as possible about it. VirtualDub is a bit bland, but it's an impossibly well understood and documented quantity.
The following users thank RobustReviews for this useful post: jsj2251 (04-12-2022)
04-11-2022, 03:40 PM
They produce mathematically identical output (hence "lossless") so they'd better!
The following users thank msgohan for this useful post: RobustReviews (04-11-2022)
04-11-2022, 04:28 PM
Touché!
04-11-2022, 06:38 PM
Definitely Virtual Dub, because of the simple, realtime-adjustable histogram. Depends on the capture device though (the IO Data GV-USB2 works well with VDub).
The following users thank Hushpower for this useful post: jsj2251 (04-12-2022)
04-12-2022, 09:39 PM
thanks!
Do you happen to know what is the most suitable lossless codec for editing on Adobe Premiere Pro?
The joys of capturing Hi8 tapes? (Not! Sony tapes suck!) NJRoadfan Capture, Record, Transfer 20 03-27-2022 09:51 AM
Capturing tapes that contain both 4:3 and 16:9 content? mountaincabbage Capture, Record, Transfer 8 04-30-2020 07:20 PM
Issues capturing VHS tapes, how to do better? bzowk Capture, Record, Transfer 9 07-30-2019 10:14 AM
Best cameras for capturing PAL Hi8 tapes? Master Tape Capture, Record, Transfer 9 08-12-2018 07:28 PM
Best choice for capturing audio cassettes? ehbowen General Discussion 7 04-02-2018 10:26 PM
