03-25-2019, 05:23 AM
Originally Posted by jwillis84 View Post
Lord Smurf always recommends by-passing the sound around the Barney dock and into a Sound Card.
The purple breakout box audio input is fine when the internal AUX channel connects the ATI AIW to the Turtle Beach Santa Cruz internally with the 4-pin cable. Less wires out of the computer, and helpful if you switch inputs often (as I do) between VCRs.
Barney dock? Is that British slang?
03-25-2019, 01:47 PM
Not the 'Blarney dock'.. the Purple Dinosaur..
03-25-2019, 02:42 PM
keaton keaton is offline
I'll check the cable itself when I get a chance, but I think jwillis is correct. Here's a capture of the ebay description:
03-25-2019, 05:43 PM
The only model/part number markings on this "hub" are on the wire of the purple input connector, which says 6110018300 D. A picture is ideal to confirm, as I have seen some results showing the other variant instead. Sometimes the site will add a -B or just a D (both of which I've seen for this RF connector variant) to the end of that number.
The model/part number marking on the non-RF connector "hub" has 6110020700G on the purple input connector wire.
So it seems they do have different model numbers, but a picture may help confirm for certain.
A post on this forum from 2 years ago seconds what I've seen: http://www.digitalfaq.com/forum/vide...html#post48393
I would suggest a note be added on the ATI MMC master thread, if there isn't already. Threads like this one tend to get lost to time, just like the one I referenced from 2 years ago. These model number differences may be useful to someone else at some point.
04-08-2019, 07:20 PM
I got a hold of a cable and found the markings on one of the breakout cables.
The parts number is clearly visible.
6110018300 D
The following users thank jwillis84 for this useful post: msgohan (01-13-2020)
08-20-2019, 07:32 AM
enois enois is offline
If needed the X800 PCIe breakout box pinout diagram can be found here:
http://www.digitalfaq.com/forum/video-capture/6855-ati-wonder-pci.html#post53661
Panasonic AG-1970 screen turns black? Chickensalad39 Video Hardware Repair 20 12-14-2018 09:28 AM
DVD freezes at black screen, locks up player? koberulz Author, Make Menus, Slideshows, Burn 0 11-18-2018 10:24 AM
Diamond ATI 600 PCIe black/green screen video input? dad2 Capture, Record, Transfer 1 02-12-2018 06:38 AM
VirtualDub and Hauppauge USB Live2 black screen? Shane Capture, Record, Transfer 5 03-21-2017 08:19 AM
Advice on Capture, Faulty Svideo Cable II zack82 Restore, Filter, Improve Quality 10 12-06-2016 10:50 AM
