My project is capturing VHS tapes from VCR with S-Video cable to Canon digital video camera pass through to computer via Firewire.
I've been reading for two whole days trying to figure out what to use to get our family videos converted from the 25-30 year old VHS tapes into digital files so I can archive and edit them and make DVDs when I can find the time to do it. I've pieced together the bits of information and come up with using Videodub with huffyuv codec to create avi files. If you have a better way, please explain what and why. I have found directions for installing Huffyuv 32 bit on Windows 7 64 bit. Will the same directions work for installing to Windows 10 Pro, 64 bit? I've also read you need 64 bit on a 64 bit machine. I know that there is also a Huffyuv multi-thread, but I don't know if it's 32 or 64 bit. Will the multi-thread just be asking for trouble? I don't see how it would save time since the tapes have to be played in real time anyway. I don't know what to use--the more I read, the more problems I read about, and the more confused I get. In case this information is needed--I have Intel Core i7-3770 CPU @ 3.4 GHz, with Quad Core, 8 logical processors, and Hyper-V support (whatever that is). Or, if my system is not compatible with Huffyuv, please recommend a lossless codec and/or a program that will work with my project. Thank you for helping me with your technical expertise. -- merged -- I kept reading and found there is a new version called VirtualDub2. Does it work well with Windows 10 Pro, 64-bit? Should I install it instead of the older version? Also I found a post that said the instructions for installing Huffyuv 32-bit on Windows 7 64-bit will also work with Windows 10. I haven't tried it yet--I want to see what the replies to my post advise. |
VirtualDub2 is a fork, not a new version. It has issues with capturing, but mostly because the fork is based off 1.10.x, which also had capture issues. VirtualDub 1.9.x best for capture.
Huffyuv original/32-bit/official version. You're overthinking the 32/64 bits. I doesn't work that way. Your bigger issue will be playback quality, recommended/good VCR, TBC, capture card. The VCR>camera does't have TBC, and DV quality loses 50%+ of the already-low VHS color. The DV transfer won't even use VirtualDub anyway, as the camera isn't a capture card. You need to back up some. You're going down the wrong path. |
LS, you've said numerous times that Virtualdub2 has issues with capturing, but I've never been able to find what those problems are or if they're still there in the current build 43382.
Erich |
OK, I’m shifting gears into reverse. Thank you for the information about which VirtualDub and Huffyuv to use. Actually I'm underthinking about the 32/64 bits, because I really don't understand anything about that subject! I wasn't specific enough about my VCR; it is a S-VHS JVC with built-in Time Base Corrector/Noise Reduction.
Your comment that the DV transfer would not even use VirtualDub was enlightening. I did some more reading and maybe I get it: the passthrough digital camera is already using a lossy DV codec to convert the analog data to a digital video AVI file, so does that make using VirtualDub redundant? I started out trying to use Cyberlink PowerDirector to capture, but it kept saying there’s no tape in the camera even when the streaming video was playing in the program’s monitor and would not “record”, so I thought I would try VirtualDub to create the DV-AVI file necessary for editing. Will it not do that? I've got to have something on my computer to take the firewire's digital stream coming in and create an editable file. I used Adobe Premiere to capture about 15 years ago, but it's editing was too slow. If I used it for capturing (if it works with Windows 10), will the DV-AVI file it creates work in PowerDirector? Isn't there a more current free software that will take the camera's throughput and make a DV-AVI file for PowerDirector editing? I'm not sure I want to buy a capture card, because years ago I made the decision to buy the digital pass through camera instead. At that time, it was supposed to offer more advantages, including better quality conversion than a card. Also the DV AVI files are much smaller than RAW AVI, not so compressed as MPEG-2, and faster to work with in editing. Back then, I was happy with the DVDs I made which looked about as good as the pitiful old VHS tapes. You seem to be saying that using the camera for the conversion rather than a capture card is losing 50% of the VHS color. I don't understand this because Hunt over at Adobe says that the compression of the DV-AVI Type 2, MS DV codec has only a "tiny quality loss, but it can usually not be detected, even with a side-by-side comparison." If a capture card is not too expensive, I’d be willing to do my own comparison before going to the time and trouble of converting 40-50 old tapes. The only available slot I have is a PCI-e. Please suggest some good capture cards, and they would have to have an S-Video port and audio ports, right? I’ve read there are now some good USB capture devices with 4:2:2 video sampling at up to 720p. Can you recommend some of them if they would be better than the passthrough camera? Thanks for your help to get me on the right path. |
Hi Oakleaf,
If you haven't done so already, definitely read this guide on understanding video sources. There seems to be a little bit of confusion here about analog video resolution. If your sources are from analog tapes, 720p isn't a resolution you should be using. It is not recommended to capture analog video in a resolution higher than 720x480. Also your footage will be captured as interlaced footage rather than progressive. Then you need to decide how you plan to store and deliver your final edited video. 720x480 is an example of a Storage Aspect Ratio. It's neither 4:3, nor 16:9. You need to decide how to set the Display Aspect Ratio of your footage after capturing. It is possible to run interlaced analog video through a deinterlacer. This step is highly recommended if you plan to create mp4 files for online streaming. The best software for this purpose is called QTGMC. However, to use this software, you need to learn how to use another software called AviSynth. AviSynth is a programming language for video editing. Basically, one will program QTGMC using AviSynth. Then, once an AviSynth code (called a script) has been written to instruct QTGMC, load and run your script with VirtualDub. This process will result in a deinterlaced AVI file. You then need to use an encoder to turn your deinterlaced AVI into an mp4. A free mp4 encoder recommended by users of this forum is called Hybrid. Hybrid can be downloaded from www.selur.de |
I was just giving the specs that said "up to 720p", not that I'm going to use that resolution. Lordsmurf was saying I needed to use a capture device other than my pass-through video camera to create an uncompressed file rather than the DV-AVI file. I'm having a hard time finding the capture hardware needed with S-Video and stereo audio inputs that will work with Windows 10, Pro 64 bit and produce an uncompressed avi file. I'd rather not have to install a PCI-e card if the USB capture device would work as well. Does anybody have experience with one of good quality?
There is no post or article at digitalfaq that advises capturing VHS to uncompressed AVI. We advise against it. It's kinda tough on CPU's and causes capture problems. You've heard of lossless high-speed compressors, right? If not, read on. If yes, feel free to read on anyway. Quote:
@Oakleaf, I've been using Adobe software and visiting their forums since 1998. They're great resources for learning advanced pro-level color correction, photo retouching, applying special effects and blend techniques, and fairly decent encoding. But when it comes to analog transfer and restoration, you won't get there with Adobe. They have no concept of restoration and their software can't be used for it. PP is inferior at resizing, deinterlacing, inverse telecine, colorspace changes, and capture. Lossless video processing is as foreign to Adobe users as it is to you, and something like QTGMC or Avisynth is out of their restricted field of view. I hung around their forums and user groups for many years, but when it came to the hard grunt of real video work from analog source, I saw more nonsense than anything else. Their approach is too destructive and ineffective. the opposite of techniques in advanced video tech forums. I'm a great fan of Adobe for cut-and-join editing, timeline, color, special effects, and I love AfterEffects. But analog transfer? Cleanup? Restoration? Adobe doesn't even make it to the ballpark. Quote:
Most of the work that you do with video for capture and post-processing with restoration apps wlll use 32-bit software. For 32-bit apps you install 32-bit plugins and codecs. You can use 64-bit software if you want, in which case you install 64-bit codecs, plugins and attachments to match 64-bit software. You can install and use both 32-bit and 64-bit software and codecs at the same time in 64-bit systems. Windows keeps track of what you have installed and what you don't. Is there an advantage to using 32-bit video cleanup apps? Yes, indeed: there are many more features, filters, and free apps available in 32-bit than in 64-bit. But you can always use both if you want. So, what's to think about? Do you know the main differences between 32-bit and 64-bit? Have you looked it up (https://www.geeksforgeeks.org/differ...ing-systems/)? Quote:
I disagree with Mr. Hunt. DV has its own signature "look". Anybody can see DV compression noise and its missing inner detail, the subtle loss of fine textures, and the levels blowout, even when the source itself is DV. DV has a very distinctive "plastic", mildly eviscerated appearance and noise profile, and it has its own peculiar form of mosquito noise, especially during motion. Nothing else looks quite like it. Take a look at the image when DV is re-encoded to DVD or h.264, and it gets worse. Quote:
VHS or other analog tape captured to any kind of digital media in a computer, no matter how it's done, will look nothing like DVD. it will look like tape, but at least slightly worse, with all of tape's simmering grain, dropouts, spots, ripples, chroma discoloration, head-switching noise, uneven side borders, possibly sloppy interace that has to be smoothed out, illegal signal levels, edge halos, DCT ringing, and all of tape's other pimples and scars. A good VCR can help minimize that, but it'll still be visible. Now, would you like to add more grunge and dirt to the results? You can do that by taking all those imperfections and capturing them as lossy DV, which adds mosquito noise and other digital compression artifacts that don't exist in analog sources, along with poor input level controls resulted in blown-out highlights and crushed shadow detail. Add buzzy, sawtooth edges from the field phase differences and DV compression algorithms, and add color translation problems between VHS and DV color storage systems (DV colors will look more raw and "baked"). Then factor in 50% chroma loss, and remove a visible amount of fine detail that gets discarded by lossy DV compression. I assume that you know what lossy compression means. It means "you lose". The data that is discarded is gone forever. it doesn't come back. Do you want to filter that grunge and noise? Think again -- it's a mess to clean up (you can't do it with Adobe anyway), and you'll need special filters that will take time and cost more detail. You've already lost a lot of data and detail anyway, and you'll lose more when you go into your final lossy encodes for your output formats. For a final format you'll use another lossy encode whether you want to or not. If you have no intention of cleaning up VHS or DV defects (and there are plenty of them, even with a good VCR), you're wasting your time capturing to a computer. Just find a DVD recorder and a smart-rendering MPEG editor and be done with it. The idea behind lossless capture is to allow lossless cleanup, lossless edits, lossless restoration and repair, and final re-encoding without intermediate damage buildup. Quote:
There are three USB capture devices that this site and others have been recommending for years as optimized for analog sources and usually run under $100. They are: lordsmurf's favorite, ATI's 600 USB dongle. They're hard to find, but you can find them sold in our marketplace. A little less difficult to find is the Hauppauge USB-Live2. A choice that's competitive with those two and easier to find, with updated drivers for XP to W10, is the Diamond Multimedia VC500 USB. It's been a favorite for years worldwide. It costs less than $50, brand new (it used to cost more, when I first bought it years ago and added it to my All in Wonder capture setup). Ignore its generic free software and use free VirtualDub or AmarecTV for capture. The USB devices will accept s-video and composite, and RCA audio inputs. VHS is captured to 720x480 NTSC (or 720x576 PAL), interlaced, with appropriate input level controls (we show you how to do that), to lossless 4:2:2 YUY2 AVI media using Huffyuv or Lagarith lossless compression. Huffyuv is faster for capture and less CPU intensive. Lagarith makes slightly smaller working files and also works with YV12, YUY2, and RGB, so it's usually used for lossless intermediate working files. Adobe PP also has problems with some popular lossless codecs, including huffYUV, which is inexcusable for a product with "Pro" in its moniker. Intermediate working files are generally not saved after a project ends. The initial capture is either archived as-is or is saved as high-bitrate compression with MPEG or h.264. If you want advice on your captures or processing, post short unaltered sample edits directly to this forum. Please don't post samples on YouTube -- no one here will deal with YouTube's ugly processing, which won't help you. If you don't know how to make and post video samples here, just ask. |
sanlyn, I appreciate your lengthy, informative post so very much. Your kindness and patience with a newbie like me is truly a blessing.
I tried to order one of your suggestions--the ATI 600 USB from the Marketplace, but I must be doing something wrong. I scrolled down to the bottom of the posts and replied asking if one was available, but got an error saying something about your token is expired. I tried again and got the same error. If I can't get that one I'll get the Hauppauge USB-Live2. Again, thank you for your recommendations. |
Oakleaf, your inquiry posted properly to the Marketplace; I saw it. As soon as the seller sees it he'll contact you to negotiate price and terms, probably via private message. Or, you can send him a PM directly.
