Drivers for ATI All-in-Wonder 9000 Pro not installing correctly?
I downloaded an ISO from this thread http://www.digitalfaq.com/forum/vide...der-hacks.html
Loaded the ISO, and the ATI Catalyst software install screen, clicked Express Install (Recommended) and it seemed to be installing everything, but after the third installer finishes i get nothing.. no signs of programs in the start menu, no notifications saying successful install, no message, no nothing.. I installed .NET Framework 2.0 SP2, and still got the same result. Whatever could be the reason as to why it's not installing? :confused: |
I found this table (with a lot more columns) at an archived UK gamers review site.
It seems to summarize the version of windows ATI cards targeted, or that the cdroms that came with the cards targeted. Their installers would then be better tested against those versions of windows, and should install correctly and completely first try. I had a problem with the AIW USB2.0 N model, and found that its cdrom installers would only correctly install on an older version of XP than SP2 (only correctly on XP-SP1), and it installed a windows update patch to enable USB2.0 before SP2 became available. (After) you allowed the cdrom to install all the ATI card drivers correctly, you could then install SP2.. but not before. Trying to install the cdrom drivers directly on SP2 the installer would only "partially" install.. you could dig them out and manually sort of install them, but they never worked right. In this case.. ATI had given an (older) version of the device drivers to Microsoft to include in XP-SP2 and that took (priority) over the driver on the cdrom.. but the driver on the cdrom was actually (newer).. so after installing SP2 you went to the driver details panel and pressed the [Rollback] button to roll-back to using the "newer" driver.. and everything worked excellently. Microsoft always placed a (priority) on out of box drivers included with windows, even if the manufacturer had something newer available. The idea was Microsoft had "superior" testing of drivers and only included the best... didn't work out that way most times. I don't know how accurate the info in the gamers table is.. there has been some controversy over even published materials from ATI.. sometimes I think its what the (wished) were true, but later turned out otherwise.
The biggest issue is the PCI and PCIe information. - The lowest 128 card had issues, don't try to use it for video capture. - The 7000 series worked on ME/2000/XP. I should know, I did it. - From our talks in the past year or so, I've come to realize the PCIe cards are using drivers that are sort of backwards compatible DX10>DX9 drivers. The PCIe cards that always given me grief, and the drivers are the problem. The hardware compression and onboard audio are terrible, the lack or proper dropped frames counter in MMC is a deal-breaker for MPEG capture, and 704 image offset is a nuisance. Quote:
I have others. I need to uploaded those. |
2 Attachment(s)
Another problem that might be related is i nearly always get this error message upon start up. http://www.digitalfaq.com/forum/atta...1&d=1560906840 I only started getting it after i placed the ATI card in the AGP slot, but at the same time i also took the SATA cable out from the optical drive and into one of the hard drives (since the motherboard only has 2 slots) I've ordered an adaptor though which should be here any day now. So i'm not sure if it's one or the other that's causing this message to appear. I have to go into the BIOS menu, press ESC then boot from HDD to bypass the error to start up Windows, since pressing F1 as stated does nothing. However after uninstalling SP2 as Jwillis suggested, restarted the computer and this popped up. http://www.digitalfaq.com/forum/atta...1&d=1560909339 So looks like SP2 was blocking something along the way, but since this PC wont be connected to the internet i couldn't download the driver update, but then i assume it's the ATI anyway, so closed the box and launched the ISO and tried installing again, but to no success. It's still not fully installing. |
I believe the "out of the ATI box" 9000 Pro, cdrom is labeled
200+DVD 180-G01445-200 Made in Canada, Copyright 2002 The driver is looking for these hardware signatures: "ALL-IN-WONDER 9000" = ati2mtag_RV250, PCI\VEN_1002&DEV_4966&SUBSYS_4F721002 "ALL-IN-WONDER 9000 - Secondary" = ati2mtag_RV250, PCI\VEN_1002&DEV_496E&SUBSYS_4F731002 The ATI MMC version on the original disk is MMC8.1 The DirectX installer included on the disk is 9.0 Later and earlier versions of ATI MMC generally work, they are looking for DirectX interfaces to act as gofers to find capture devices. But the original software will be more aware and better matched for that specific card. LordSmurf has "deep" and "thorough" experience in extracting the very best performance from these cards. He knows them inside and out far better than I do. But as a baseline, the above information is what came with my ATI 9000 Pro. BTW: The SM Bus controller is part of the chipset driver for the motherboard. If there is not a chipset driver for your motherboard that works with that version of XP it will remain unidentified. SM - Systems Management, is usually for temperature monitoring and fan control. BIOS can set the fan to a static speed, but an SM driver lets the operating system measure temperature and ramp the fan speed up and down as necessary. Update: I found a cdrom labeled 100+DVD 180-V01084-100 Made in USA, Copyright 2004 The driver is looking for these hardware signatures: "ALL-IN-WONDER 9000 SERIES" = ati2mtag_M9, PCI\VEN_1002&DEV_4C66&SUBSYS_4F721002 The ATI MMC version on this disk is MMC8.8 The DirectX installer included on the disk is 9.0a It "should" work, but appears to be the cdrom included with the ATI 9800 since the driver inf file mentions that model. "DO" take note that the hardware identifier is "different" however. PCI\VEN_1002&DEV_4966&SUBSYS_4F721002 (not) PCI\VEN_1002&DEV_4C66&SUBSYS_4F721002 DEV_4966 (vs) DEV_4C66 You could go into the Device Manager and right click any yellow safety cone icons and go to Properties > Details Drop down to Hardware Ids and see what your cards hardware identifier is. It may be that its hardware id matches a different cdrom image for the ATI 9000, or that this later version of the driver has a typo in the distribution cdrom hardware id since it was intended for the ATI 9800 card and the ATI 9000 may have been long off the market by release.. so no one bothered to catch the typo. BTW: you can "force" a driver to be installed for a device manually by right clicking an unidentified hardware device and selecting "Let me choose" and pointing at the driver directory, then unchecking the list "compatible" drivers box.. this will (override) matching the hardware ids, and gets around manually editing the inf file to make it match your hardware id. Its not easy.. and I am not sure I would recommend it.. it can be a hard to recall procedure and reproduce later. But the benefit (might) be a newer driver (unlikely trustworthy if they had an uncaught typo in the installer file) and a newer version of MMC8.8 as opposed to MMC8.1 - but you can also mix and match MMC versions outside of the installer.. its just another hard to recall procedure. (My recommendation) would be to use the original boxed cdrom image and let the installer do all the work. |
Ah so it's the wrong ISO file, going by the copyright year 2004. The 9000 came out some time before that, 2002 i think. Wish i had the original CD ROM it came with, but i got the card itself fairly cheap on an auction.
I couldn't see any Details tab in the Device Manger properties to see the Hardware Ids. |
8 Attachment(s)
I am certain LordSmurf has a copy. He has vast archives of material.
But I can make an iso file image of the cdrom if needed and upload it. The only thing about using the 2002 cdrom is I'd recommend using XP-SP1 before applying the SP2 service pack, and making sure you know the Device Driver version numbers both before applying the SP2 and after.. in case you have to hit the [Rollback] button to get back to the newer device driver. Like I did with the "ATI USB2.0 N".. it may not occur with your card.. but it may. -- merged -- I found two ATI 9000 Pro cards, one was still sealed in its box with shrink wrap. The shrink wrapped card cdrom was labeled: 180_G01445_100 The non-shrink wrapped card cdrom was labeled: 180_G01445_200 The contents of each cdrom appear identical as close as I can see. The Hardware ids in the .inf files also appear identical. I do not know what the difference between the two are, but some of the directories on the 100 disk have a date stamp from 2/2003, those same directories on the 200 disk have some with date stamp from 6/2003. My guess is there is a difference, but that it would be minor. I could do a Beyond compare of this discs or a binary compare.. but I don't have the time right now. Instead I made disc images of each cdrom and uploaded them as rar attachments to this message. You probably only need one of them. But your welcome to both. The choice of which to use is up to you. Based on the date stamps, XP or XP with SP1 installed are probably what was available at the time the installers were developed. And that is probably what they tested the installer with. XP without SP1 is kind of hard to use, its got a few bugs. Don't try installing any version of .NET before you try to run the ATI installer from the cdrom. Also don't try installing any version of DirectX 9.0 (I think) all of those that are required are on the cdrom and will be installed as needed. And they would be the versions that were tested with the ATI installer. "Newer" is not better in this case, because "newer" means they had an opportunity to add features and take away features and that breaks the reliability of the testing performed on the ATI installer when it shipped. Good luck |
1 Attachment(s)
Thanks for those files. Unfortunately when i run either, it spat up this error.
http://www.digitalfaq.com/forum/atta...1&d=1561016937 And yes, i have SP1 installed and .NET Framework uninstalled. |
1 Attachment(s)
The most common one cited as the problem is for %ALLUSERSPROFILE%\Desktop
Create the folder "Desktop" in c:\documents and settings\all users\ Then reboot and try to run the ATI installer again. Refer to the attached file if that does not work, Page 2 - For Windows NT, 2000 and XP Users |
There is already a folder called Desktop in that location.
Looked through the attached PDF, and checked through but all seems normal. I think i'll try doing a clean install of Windows and re-installing everything again but i'll wait until the SATA adaptor arrives as don't currently have my optical drive hooked up as mentioned earlier. |
I've a system I can quickly restore XPHSP0 and try an install with each.
I'll try it now and report back. -- merged -- XP Home no Service Pack installed Using the 180-G01445-100 Install completed without error I setup the TV application and it displays static, as expected I can think of twelve permutations to try to "force" the error message you are seeing. Could you help me out by selecting the case that matches yours the closest? Home 1. XPHSP0 + 180-G01445-100 (tried succeeded without error) 2. XPHSP0 + 180-G01445-200 3. XPHSP1 + 180-G01445-100 4. XPHSP1 + 180-G01445-200 5. XPHSP2 + 180-G01445-100 6. XPHSP2 + 180-G01445-200 Professional 1. XPPSP0 + 180-G01445-100 2. XPPSP0 + 180-G01445-200 3. XPPSP1 + 180-G01445-100 4. XPPSP1 + 180-G01445-200 5. XPPSP2 + 180-G01445-100 6. XPPSP2 + 180-G01445-200 assuming (no XP 64 bit versions or Win2003 Server versions are involved, and no multilinguals or nationals are added) any details would help i'll try restoring then adding SP1, SP2 and keep stepping through the possibilities -- merged -- Home 1. XPHSP0 + 180-G01445-100 (tried succeeded without error) 2. XPHSP0 + 180-G01445-200 3. XPHSP1 + 180-G01445-100 (tried failed, aticim.bin event 1000) 3. XPHSP1 + 180-G01445-100 (changed cpu date to 2003, tried succeeded without error) 4. XPHSP1 + 180-G01445-200 5. XPHSP2 + 180-G01445-100 6. XPHSP2 + 180-G01445-200 have to stop now, will pickup tomorrow evening |
Well i've tried all these combinations but still getting the same error every time.
Professional 1. XPPSP0 + 180-G01445-100 2. XPPSP0 + 180-G01445-200 3. XPPSP1 + 180-G01445-100 4. XPPSP1 + 180-G01445-200 5. XPPSP2 + 180-G01445-100 6. XPPSP2 + 180-G01445-200 Are the ISO files both 651mb? |
180_G01445_100.ISO 666,870 KB
180_G01445_200.ISO 666,864 KB You should try to set the Clock on the PC back to the year 2003. Some of the certificates in the installers appear to have expired by 2019. There are differences between XP Home and XP Professional. XP Home was usually targeted as a Gamers platform and these cards tended to be bought for gaming. XP Professional was not a superset of XP Home, trade offs were made to change the value equation. And defaults were different in several components. I will switch to using XP Professional for testing. It will take a little time, XP Professional is a "fussier" install than XP Home. |
Disregard that, just XP declaring incorrect file sizes, shows the correct size on Windows 10.
Tried going back to 2003, but that didn't seem to do anything either. Hmm, perhaps it's a problem with Professional itself. |
1 Attachment(s)
will resume testing this evening
P could be the issue, we will see -- merged -- Professional 1. XPPSP0 + 180-G01445-100 (tried succeeded without error) 2. XPPSP0 + 180-G01445-200 3. XPPSP1 + 180-G01445-100 (tried succeeded without error) 4. XPPSP1 + 180-G01445-200 5. XPPSP1a+ 180-G01445-100 (failed, tried again, succeeded distorted video window) 6. XPPSP1a+ 180-G01445-200 7. XPPSP2 + 180-G01445-100 (fails with ATI CIM conflict with USER32.dll) 8. XPPSP2 + 180-G01445-200 The simplest install is with XP Professional with No Service Pack applied. That glides to success each time. The next simplest is XP Professional with the (genuine) Service Pack 1. That succeeds with no errors each time. Microsoft released an update to the Service Pack 1 called Service Pack 1a and did a fair job of scrubbing downloads of the (genuine) and original Service Pack 1 from the internet. It is a bit hard to find these days. Service Pack 1a "appears" almost the same size.. but is known as their second take on Service Pack 1 and they changed a lot of things. This shows up as instability and general modifications to the default settings for many applications. I did not test with SP1a the previous night on XP Home, but would expect similar distorted and unpredictable install behavior.. sometimes it succeeds, sometimes it fails.. it seems something in the background is on a variable time loop after SP1a is applied. Once it does succeed, the video window is shrunk from Full size to a postage stamp. It can be readjusted.. but a guess is Microsoft changed the APIs in SP1a and the Installer from ATI was relying on "stable" APIs not to change in a revised SP1a. I would very much recommend (not) using SP2 with this card. And if SP2 has ever been on the system it cannot truly be removed, so start over with a fresh install of XP -- merged -- I am quite surprised by these results! Professional 1. XPPSP0 + 180-G01445-100 (success) 2. XPPSP0 + 180-G01445-200 (fail) 3. XPPSP1 + 180-G01445-100 (success) 4. XPPSP1 + 180-G01445-200 (fail) 5. XPPSP1a+ 180-G01445-100 (fail/success) 6. XPPSP1a+ 180-G01445-200 (fail) 7. XPPSP2 + 180-G01445-100 (fail) 8. XPPSP2 + 180-G01445-200 (success) In other words 1. XPPSP0 + 180-G01445-100 (success) 2. XPPSP1 + 180-G01445-100 (success) 3. XPPSP1a+ 180-G01445-100 (fail) 4. XPPSP2 + 180-G01445-100 (fail) 5. XPPSP0 + 180-G01445-200 (fail) 6. XPPSP1 + 180-G01445-200 (fail) 7. XPPSP1a+ 180-G01445-200 (fail) 8. XPPSP2 + 180-G01445-200 (success) 180-G01445-100 works for XP SP1 and SP0 180-G01445-200 works for XP SP2 The last three digits "appear" to indicate the Service Pack they were tested with or intended to work with. Checking after 180-G01445-200 was installed on XPP+SP2 reveals the ATI drivers from the ATI Installer were installed (and removed the Microsoft boxed drivers). It put back the older ATI drivers that work, simplifying the install if you already have SP2 installed. I'll go back to testing with XP Home and see if this confirms the theory. -- merged -- This has been confirmed for both XP Home and XP Professional edition: 180-G01445-100 works for XP SP1 and SP0 180-G01445-200 works for XP SP2 and SP3 -- merged -- I never got the same error message you did when installs failed. Once you select the appropriate version 100 for XP with SP1 or 200 for XP with SP2 You may still get the same error you experienced before. However I noticed you have some type of antivirus running in your XP system tray, the Life Preserver indicates something running that is probably blocking the Installer. Disable the antivirus and see if you can run (the appropriate) installer for your version of XP. I think it will succeed without producing an error. |
I don't know about the life preserver icon, but the previous post shows an image with the XP "Found New Hardware Wizard" and the ATI installer running at the same time. Never install an ATi-AIW product with the Found New Hardware Wizard.
Uninstall the ATi software if anything was installed. Delete the ATI program folder. Check the Device Manager in Control Panel and uninstall any hardware reference to an ATi card, if it exists. Reboot the PC. When the Found New Hardware Wizard starts, turn it off. Start the ATI installer separately, by itself. |
I've been racking my brains trying to recall who used the Life preserver icon.. I think it was an early version of AVast or some other antivirus that had a Pirate sounding name.
The same icon was often used for Help or Info, but in the start menu, not in the systray. The systray was reserved for "running" programs.. so I feel sure there is something running there. I simply don't know for sure what it is. The 800 error message by the installer was a generic "catch all" error message which didn't ford much information other than it was blocked or had stopped gracefully. A different catastrophic C++ message from a Catch Try Fail block would have returned a much ruder and intolerant message if it wasn't something simple like a file access denied.. which is what antivirus specialized in. |
Well things got a bit busy.. so put this on the back burner for a while (can't believe it has been 6 months!) anyway hope to continue were we left off.
Still not getting anywhere with this. Getting the same error everytime. Tried doing a clean install of Windows, but can't get the CD to boot up. And that program in the taskbar isn't an antivirus, but a program called Gizmo, used to mount the ISO and launch the installation file. |
Master Tape i did use the drivers and MMC 8.8 that is on the disc 180-V01084-100 on my Ati All in wonder 9000 and i use WinXP PRO SP2 when i install it
i did not have any problem when i did install it here POST nr 20 http://www.digitalfaq.com/forum/vide...html#post14940 one more thing i have noticed if you have installed the drivers and you have a exclamation mark in device manager on the drivers then you have to shut down the computer and unplug it from the wall socket or turn off it from the power supply and then press the computers power button so it empty all the power from the computer then you can start the computer again :) |
