11-05-2019, 02:06 PM
emmykat690 emmykat690 is offline
Is there a product to clear up quality when converting vhs home movies?
11-05-2019, 03:58 PM
What ???????
11-05-2019, 07:01 PM
2ball 2ball is offline
how are you converting them?
11-06-2019, 05:26 PM
Recording analog video directly to lossy codecs such as MPEG using a DVD recoder is one of the lowest-quality methods for digitizing home tapes. It increases the original noise levels and makes cleanup extremely difficult, in come respects often impossible. Analog sources are for cleanup and restoration are usually captured to a PC using specialized codecs for lossless compression, and processed using apps like Avisynth and Virtualdub. "Editors" are used for editing, not for cleanup.
If you care to take a look, a thread showing details of a restoration project was updated just today: http://www.digitalfaq.com/forum/vide...lor-spots.html. The forum has thousands of posts about capture and cleanup. Try the restoration section at http://www.digitalfaq.com/forum/video-restore/
Workflow suggestions: home movies, all VHS, different formats? IcoPro Project Planning, Workflows 1 08-12-2019 09:24 PM
Distorted sound and picture on home movies 123Donnie Restore, Filter, Improve Quality 6 08-18-2017 08:01 AM
How to fix rainbow effect on home movies? Roquefort Capture, Record, Transfer 3 02-14-2017 07:56 AM
Converting home movies -- need advice Jpass992 Capture, Record, Transfer 10 07-17-2013 08:04 PM
Transferring home movies from VHS camcorder (A New Beginning!) ErikCalifornia Project Planning, Workflows 16 03-19-2013 03:31 AM
