02-04-2004, 11:21 AM
jrnyhead jrnyhead is offline
Using Womble MPEG Wizard to edit the video, I'm having problems with the "sound line editor".
Using the sound line editor, I would cut, (not delete, just cut between the area where I want to edit the audio) use the sound line editor to fade either in or out using markers (pionts) and then the audio would not play during playback.
Or, I should say, sometimes the audio would play, and sometimes not.
After each audio edit, I would save the file, so saving is not the problem.
It seems this is sporadic!
- jrnyhead
02-05-2004, 01:43 PM
I've never used this program, but I'll look at a trial (if one exists) and see if I can recreate the issue.
I do know that the fade utilities on Womble MPEG-VCR would often crash my Windows ME system, but work fine on my Windows XP Pro system.
02-08-2004, 12:00 AM
Lordsmurf:"I've never used this program, but I'll look at a trial (if one exists) and see if I can recreate the issue.
I do know that the fade utilities on Womble MPEG-VCR would often crash my Windows ME system, but work fine on my Windows XP Pro system." </font>
Did you get a chance to try to recreat this audio fade problem? There is a 30 trial on Womble's website.
02-08-2004, 12:40 PM
I've not been able to re-create the problem. Still testing.
Editing with Womble MPEG Video Wizard [VIDEO GUIDE] admin Edit Video, Audio 12 03-05-2009 10:39 AM
Womble Mpeg-Vcr problem-HELP!!!! MagnificentMarcus Edit Video, Audio 12 03-09-2008 04:44 AM
Audio sync problems with Womble MPEG2VCR mlaviolette Edit Video, Audio 3 10-14-2006 11:53 AM
Using VirtualDub for editing MPEG video admin Edit Video, Audio 0 11-16-2005 04:20 AM
Video editing - general myron Encode, Convert for discs 2 04-28-2004 04:29 PM
