Capture interlaced, but how to to keep video interlaced when making DVDs?
Haven't done this before, not sure if its automatic or if it will fall off when I make DVDs or Blu-Rays
Fall off? :huh1:
Just encode to MPEG as BFF (DV sources) or TFF (everything else), author the BD/DVD without re-encoding, and it will be fine. |
Good encoders should let you specify interlaced vs progressive encoding. What are you using to encode?
I haven't decided yet. I prefer not to deinterlace so I am rummaging the forums to find a good encoder to do this.
- Avidemux = free but buggy
- TMPGEnc Plus 2.5 = cheap ($37) but slower to encode - MainConcept Reference (now TotalCode Studio) = expensive ($500+) but best in the industry. There's not a lot of choices for MPEG encoders. I use them all, dependig on the computer and the task. |
They're standalone programs.
Adobe Premiere comes with the MainConcept SDK encoder (the "Adobe Media Encoder") VirtualDub only exports AVI. |
1 Attachment(s)
The MPEG-2 MP@HL is 100 Mbps. DVD-Video is max 9.8 (or 10.08) Mbps. It doesn't go to 16 anyway Blu-ray MPEG-2 is 15 Mbps. So not sure what you're referring to. :question: Attachment 3658 Note that video is 1000, not 1024 base. |
I ended up not being happy with the quality outside of cartoons with what I was getting. Because my size allowance is so big, I ended up muxing to Lagarith instead for smaller sizes with same quality. I wanted Huffyuv but it was giving me grief.
