12-01-2005, 02:28 PM
Tom_n_Jonna Tom_n_Jonna is offline
Hi Tech Gurus...
Yet another question...
I've captured several shows with my DVD Recorder and have transferred them to my computer's HDD and want to know if I can encode them as AVI's to take up less room and then later, when I have time, make them into DVDs?
Thoughts??
Tks, as always, Tom
Cheers...Tom
12-01-2005, 11:55 PM
allaboutduncan allaboutduncan is offline
You could do that, but I wouldn't reccomend it. I'm sure LS can you the technicals reasons and aspects, but in plain speak, it just wouldn't work very well.
Uncompressed AVIs are the best thing to use to make DVDs and they are much larger than MPG files. To get an AVI to a reasonable size, it would need to be compressed using a compression codec like DiVX. However, DiVX doesn't convert well back to MPG (for DVD) and by the time you copress to DiVX and then back to MPG, the quality will be horrible. Not to mention, all that encoding and re-encoding would take hours for each file.
Buy a pack of DVD-RWs and drop the MPGs onto them, pull them off when you're ready to author. That's probably the easiest and best solution.
12-02-2005, 03:33 AM
Thanks Bro...
That's actually what I'm doing now, so will stick with it.
Cheers...Tom
Cheers...Tom
Converting a 12GB Mpeg to a 4GB Mpeg Konfusion Encode, Convert for discs 1 09-03-2007 06:06 AM
MPEG question battle7 Edit Video, Audio 3 07-07-2005 06:29 PM
MPEG-2 vs. MPEG-2 DVD in MMC TV Capture JimGorsline Capture, Record, Transfer 4 07-09-2004 02:20 AM
