10-07-2015, 10:25 AM
momnewbie momnewbie is offline
I have a video in a large .WMV file. I would rather not put it through another encoding process to preserve as much quality as possible. Maybe this is a "duh" question but could I just save my file onto a Blu-ray disc and still be able to view it on my computer, ps3, and other Blu-ray players? Thank you
10-07-2015, 11:07 AM
Yes, you probably can.
It really depends on the exact model of Blu-ray player, and it's abilities. Some Blu-ray players insist that BD media must contain a BD movie. The WMV will probably fit on a data DVD as well. I've never tested this on my Samsung player. I usually just use Serviio to stream MP4 and AVI. You'll just need to test it. Burn with DVD if you can (cheaper).
The following users thank lordsmurf for this useful post: momnewbie (10-10-2015)
10-07-2015, 12:34 PM
You might be able to find a set top player that can play WMV, but I never heard of one. WMV is native to Windows, which is why most Windows PC players can handle it. However, WMV is not a "format", it's a container or wrapper that can contain video encoded with a number of different codecs, frame dimensions, frame rates, audio codecs, etc. Set top players are not PC media players. They can handle several formats, but only within a limited set of standardized encoding specifications. Even if they could play WMV, the low bitrates and small frame sizes used for WMV (it was designed for 'net streaming, not for disc playback) will upscale poorly on HDTVs.
10-09-2015, 11:01 AM
Thank you so much, Lordsmurf and Sanlyn. I really appreciate your help. I just found out (through GSpot) what codec my video was saved as.
Since it is dvsd does that mean it only encoded it once as it passed through my DV camera? Is this the same codec that my DV videos are? Is dvsd easily played on common Blu-ray players?
The reason I was opting to save it to Blu-ray was because it is 24.7 GB and I didn't want to compress it and lose any more quality. Do you think it is worth it to compress it again? Or should I stick with Blu-ray?
Do you know why my audio information does not show up? I know the video does contain audio
Thanks a ton in advance!
10-09-2015, 12:28 PM
Goldwingfahrer's Avatar
Remembered
Possibly the fact that there no audio is in it.
Control with media info
Here an example, however, with CDVC [Canopus DV-AVI]
File Type: png GSpot v2.70a 2.9600_Neu_2015-10-09_19-25-31.png (103.3 KB, 2 downloads)
10-12-2015, 11:39 AM
Ok, so I am ready to burn my Blu-ray on ImgBurn. It is telling me since it is an AVI file I should choose the ISO9660 +Joliet not UDF.
* When I choose the ISO+Joliet it tells me that my file size is too big and I need to either switch back to UDF
or--- Enable the Allow Files Exceeding Size Limit and Multiple Extents options in the ISO tab
I just want the best option for having my "data" play on as many players (stand alone, pc, Playstation, etc) as possible. I am getting conflicting information as to which option is best. UDF or ISO+J with mulitiple extentions?
.wmv, data
Large file after using filter in Virtualdub Jasen Restore, Filter, Improve Quality 11 07-19-2014 04:17 AM
Long time to burn and extract DVD data disc gamemaniaco Blank Media 27 10-15-2013 06:58 AM
Need to Share Large Files Online? / Free file sharing sites admin Computers 0 12-02-2009 11:30 AM
Extracting a quicktime film from a large data file Tranzor Computers 3 07-14-2006 10:02 AM
DVD Shrink file still too large? battle7 Copy DVDs, Duplicate, Replicate 1 06-02-2005 11:45 PM
