03-25-2006, 07:37 AM
Nosinik Nosinik is offline
I've been working on a dvd set this week. I use Video Redo to prep the episodes for authoring with DVDWS 2. The created MPEGs have perfectly synced video and audio, but after authoring, are completely out of wack. I used to have the same problems backing up my BTAS and STAS discs, but Video Redo always made them perfect. Has anyone figured out a workaround for this?
03-25-2006, 08:16 AM
You're using commercial source? Or homemade source? Big difference.
03-25-2006, 08:18 AM
It is a commercial source. I bought it this week but I like to add chapters.
03-25-2006, 08:47 AM
Rip in IFO mode in DVD Decrypter. Should give each episode in separate file.
Use "VOB Edit" (name of software) to demux audio and video, do each demux stream separately. Commercial releases have a LOT of stuff in the streams, this is your problem.
Then remux (if needed, probably not) in TMPGENC (file -> MPEG tools) and then edit in VideoReDo, if needed. Again, probably skip all this.
Import a/v files into authoring software, re-author with new menus, add chapters as wanted.
Done.
03-25-2006, 10:47 AM
Ugh.
Still didn't work. I followed your instructions but I still get the same problem. I used DVD Decrypter (last available version) in IFO to rip one episode. I then used Vobedit v0.6 to demux each stream (video and audio) separately. I then remuxed them with TMPGEnc. A quick run through VideoRedo (v2.2.1.445) and placed into DVDWS2 (with all updates) for authoring. The episodes start out good, but quickly begin to shift out of sync until the end where it is 1-2 seconds out.
Maybe this is some kind of new copy protection. Any other ideas, LS?
03-25-2006, 11:23 AM
I have no idea. This is one reason I thoroughly hate to re-author commercially released videos. The MPEG video stream may be dirty, would be my next guess. Run it through RESTREAM and turn on all the various cleaning-type options.
03-25-2006, 11:37 AM
I've never used that tool before. I'll research it and try it out. Thanks for the help, LS.
03-25-2006, 12:20 PM
Check this out:
http://www.digitalfaq.com/dvdguides/...g/restream.htm
See the "advanced usage" note.
And then do these:
03-25-2006, 11:48 PM
Well ReStream did it. When I would run it with the settings checked, there were always problems. By some fluke, I ran the video stream through it without any of the settings checked and the resulting stream was authored with no out-of-sync issues. Strange to be sure.
Thanks for introducing me to this program LS!
Question about audio sync on certain burns Damien Videography: Cameras, TVs and Players 1 03-20-2009 09:22 PM
Mpg/Vob audio Gradually goes out of sync Konfusion Restore, Filter, Improve Quality 6 01-13-2008 01:10 AM
Audio-video out of sync, other problems yargellham Capture, Record, Transfer 7 11-20-2005 02:28 PM
Audio video sync errors 777sp2 Capture, Record, Transfer 9 11-18-2005 03:33 PM
ATI/Creative Audio/Video sync problem Edye Capture, Record, Transfer 4 11-21-2004 03:12 PM
