digitalFAQ.com Forum (http://www.digitalfaq.com/forum/)
-   Encode, Convert for discs (http://www.digitalfaq.com/forum/video-conversion/)
-   -   How to load BD files into VirtualDub (http://www.digitalfaq.com/forum/video-conversion/7921-how-load-bd.html)
metaleonid 04-04-2017 09:55 PM
Anyone can help loading files?
I tried FFMpegSource2 and the function is not found.
DirectShowSource says format is not supported. Do I need to download specific codecs?
lordsmurf 04-04-2017 10:09 PM
What do you mean "BD" files?
Are you referring to M2TS files?
metaleonid 04-04-2017 10:14 PM
Yes, there are m2ts files I am trying to load. I am on 32 bit XP. Should it make a difference?
Site design, images and content © 2002-2020 The Digital FAQ, www.digitalFAQ.com
Forum Software by vBulletin · Copyright © 2020 Jelsoft Enterprises Ltd.
