07-17-2006, 03:59 PM
cp32 cp32 is offline
I should have checked the resolution before using them
They are little pixelated when played on the dvd player.
I used Ulead to author the dsc. It didnt crash for once
I have 2 .mov files.. the problem is they are 162 X ??? very small.
Even in vcd they are pixelated... Procoder will convert them.
How Do i convert without turning it into crap?
Is there something you can do LS with virtual dub ? the files are small. not even 10 mb.
07-17-2006, 10:36 PM
VirtualDub, use the "MSU Deblock" filter.
07-18-2006, 12:52 AM
Tcel93 Tcel93 is offline
CP, CP, CP.....why art thou dealing in low resolution.....
07-18-2006, 01:31 AM
Thanks LS. TC you keep pushin my buttons.
I ll hitch a ride to your home. Just to kick your ass Can I reach that high? Better take a step ladder too .
07-18-2006, 02:06 AM
You do it LS , pleae? This crap monitor is hard to judge accurately.
Please????
07-19-2006, 01:32 AM
Sent the files LS. Help!!!!
Benchmarks for using Procoder 3 lordsmurf Encode, Convert for discs 2 09-01-2010 04:08 AM
Tips for Quicktime with Sony Vegas cp32 Edit Video, Audio 1 07-14-2006 07:46 PM
Extracting a quicktime film from a large data file Tranzor Computers 3 07-14-2006 10:02 AM
How to convert a Quicktime file to DVD format ? d.smyth Encode, Convert for discs 1 03-25-2006 03:14 AM
Procoder 2.0 to shrink 6GB video to single layer DVD ? MBates05 Encode, Convert for discs 19 12-19-2005 04:45 AM
