-   Encode, Convert for discs (https://www.digitalfaq.com/forum/video-conversion/)
-   -   Must combine multiple short films to Blu-ray? (https://www.digitalfaq.com/forum/video-conversion/9861-combine-multiple-short.html)
waloshin 07-16-2019 11:20 AM
I must combine mulltiple short films to a bluray for an upcoming film festival. Typically the videos are 1080p 24 abd 23.97 some sre 25 fps. What is the quickest and most affordable software to encode them as bluray i do not need any menu.
SPiel 09-25-2019 09:29 AM
Recommend using Movavi Video Converter, it supports every video format out there, so there should be no quality loss thanks to its encoding algorithms. You can grab it here https://www.movavi.com/videoconverter/
waloshin 09-25-2019 09:41 AM
Thank you I ended u going with Tmpgenc authoring works 6 which worked great especially with the batch processing.
SPiel 09-27-2019 09:37 AM
You're welcome!
