01-31-2021, 07:28 PM
BOBcat76 BOBcat76 is offline
I have converted my 8mm analogue home movies to digital files by year and separated them under 2 topics like "family" and "annual golf with friends"
I'm thinking my next step is to try and enhance bad lighting/adjust color cut out unnecessary frames. Am I correct that this is such basic editing? I should seek the "most friendly"/ possibly free software. Do you have a recommendation for easiest to use?
DaVinci tutorials are intimidating on first viewing.
I'm assuming, just like any document, any of my new files I edit, get saved as a post edit/new name and nothing happens to the original, yes?
What I could have included was my problem of the most basic step of getting 2 related clips into the editing window prior to editing. It seems having a better filing system so I can drag and drop clips from just one file, I can then combine them to edit. Is there an "editing" term for this simple act of copy pasting before editing actually begins? "Opening 2 or more clips"?
02-06-2021, 08:24 PM
Adjusting color seems simple, but it's really not. It's both science and art.
There's several great options, such as:
- basic VirtualDub (with Colormill plugin)
- somewhat complex Avisynth scripting
- the DaVinci pseudo-NLE
- and quite a few others, both suggested software, and lousy software -- so be careful!
All of them require a learning curve, but can do what you want. For color correction, I really don't think any of them is easier than the others.
Most video/NLE software requires an export to get a new clip. Merely "saving" the project saves the timeline information, not a new video. I'm not sure if that's what you're asking here?
As far as the "getting 2 clips" issue, it sounds like you want something with a timeline, to add multiple clips, and adjust each independently?
Color issues in VHS video, editing issue after capture? billybatts Restore, Filter, Improve Quality 2 06-21-2021 07:33 AM
Hi8 capture filtering. color correction? sinul Restore, Filter, Improve Quality 2 06-10-2021 02:46 PM
Elite BVP4 video proc amp vs. VirtualDub color correction? filmnoobies Restore, Filter, Improve Quality 3 05-20-2018 10:32 AM
Best affordable IPS monitor for video color correction? VideoTechMan Computers 5 01-07-2016 09:45 AM
