I have been using Smart Cutter to cut my over the air .TS files, but it has lots of issues. Lordsmurf (in another forum) suggested that I give MPEG2VCR or MPEG Video Wizard a try. I had codes for both but haven't used them in over 10 years and assumed they wouldn't work on a newer OS, but thankfully they both have worked. However MVW has caused some issues with the subtitles.
The original file info:
Duration 32 min 58s
Video: MPEG2
Resolution: 704x480
Audio: AC-3 2 channel 48khz
Closed Caption: EIA-608 muxed in video #1
The closed captioning can be enabled and is fine in the original file. But after I cut out the commercials with MVW 2005, the Closed Caption is still there, but the letters are all scrambled up.
For example:
Original:
I'm gonna make
bacon and eggs.
MVW 2005:
I'gom manna ke
n baco and eg.gs
Smart Cutter never messed with the captioning, otherwise MVW 2005 worked so much better. Is there anything I can do to prevent this?
I tried installing the MPEG Video Wizard DVD 4 that I found on this forum, but as expected, my code wouldn't work for it. Thanks for any suggestions.
