02-06-2022, 10:36 AM
SeveralOrange7639 SeveralOrange7639 is offline
I have captured a few of the tapes with Virtual Dub on another PC of mine running Windows XP. I have copied the files to my main PC which I am wanting to edit them on. I also have Huffyuv installed on this PC and the videos play in VLC without issue.
I tried editing them in Premiere Pro first as I already had this installed and familiar, with the software, but it gave me an error. I then tried editing in Vegas as I had an install from years ago on my PC, this gave me a similar error. I finally tried Corel Video Studio on a trial as saw it recommended on here, this game me a similar error too.
I'm not too fussed about which editor I use, the main thing I am looking to do is splitting up the captured tapes into events/clips, maybe make other small adjustments.
I have attached screenshots of the errors and the codecs section of system information and the media info that VLC shows.
It could be something simple, but I haven't been able to figure it out yet.
02-07-2022, 05:16 PM
You need the codec. What was the capture codec?
VirtualDub captures 32-bit with 32-bit codecs.
New NLEs are all 64-bit.
Not a problem, the 64-bit needs to be installed. But NOT to be confused with Huffyuv64 or HuffyuvMT.
Install ffdshow, enable the FFHuffyuv, which should add x64.
codec, edit, editing, huffyuv
Can't sync iPhone video files in Adobe Premiere? BayAreaSean Edit Video, Audio 2 09-23-2017 04:06 PM
Adobe Premiere CS3 for compressing video? JoRodd Edit Video, Audio 16 05-11-2017 09:49 PM
Is there an alternative to Adobe Premiere? rappy Edit Video, Audio 1 12-27-2011 12:31 PM
How to Edit FLV in Adobe Premiere with low-cost plugin teddyB Edit Video, Audio 1 01-21-2010 10:39 AM
