04-12-2022, 09:53 PM
jsj2251 jsj2251 is offline
I'm going to capture Hi8 tape using huffyuv codec on AmarecTV.
Does Adobe Premiere Pro experience problems or losses when editing video files captured with the huffyv (x32) codec?
(Use Windows 10.)
Which lossless codec is best for editing using Adobe Premiere Pro?
(I heard there are magicyuv, ut video, lagarith besides huffyuv.)
08-07-2022, 09:00 PM
Premiere Pro uses whatever the system has installed. So (for SD) Lagarith, Huffyuv, and others.
For HD, FFV1.
Laggy video after using lagarith codec with premiere pro banane Edit Video, Audio 1 01-16-2019 04:08 PM
How to make a Lossless x264 preset in Adobe Premiere? Astralogic Encode, Convert for streaming 0 07-27-2018 06:32 AM
Need a lossless YUY2 codec that works with Adobe Premiere 64-bit hysteriah Capture, Record, Transfer 9 04-15-2015 04:51 AM
Editing YUY2 footage in Adobe Premiere - Will colorspace conversion occur? hysteriah Edit Video, Audio 0 03-08-2015 04:28 PM
