Quantcast How to create mix DVDs, compilation DVDs? - Page 2 - digitalFAQ.com Support Forum
Go Back   digitalFAQ.com Support Forum > Digital Video > DVD Project Help > Edit Video & Audio
02-23-2010, 07:54 PM
However...some of them also will only be like 8-10 min a clip...when I encode one of those clips that is like 8 min, what is the max bitrate that I should use for a clip that small in length?
Bitrate is selected on the basis of full disc length. There is also a maximum allowed bitrate for the DVD-Video specification.
If the whole new DVD is going to be 8 minutes long, then you can max it out at 9800k video+audio.
If the new DVD will be longer, add your minutes together, and use a bitrate calculator.
This topic was recently discussed at: http://www.digitalfaq.com/forum/show...16&postcount=2
with DVD Fab, and everytime I click the start button, it says no writeable media found in my drive, and it ejects the DVD that I'm trying to rip.
You've picked the wrong program mode, or it has the target set to another CD/DVD drive instead of a hard drive (files or image).
__________________
If this site has been as helpful as a book or magazine, then Donate a few Dollars or Upgrade your Membership.
02-23-2010, 09:19 PM
Superstar Superstar is offline
"If the new DVD will be longer, add your minutes together, and use a bitrate calculator. "
Each DVD is going to be about 3 hrs, as you suggested that I do since it's going to be such a big set.
Each clip will be in between 5-45 min. long, and my original plan was to try to encode a lot of the clips 1 at a time..so, I'd just import one match into MC, encode it..do the same for another..etc..
That's what Im confused on about the bitrate..
There's going to be about 5-7 seperate clips on each dvd, imported seperately into workshop..just like the one we made together when you taught me how to use workshop, Im not sure if you remember that or not.
02-23-2010, 09:39 PM
If the full DVD will be about 3 hours long, then each clip will be encoded to a bitrate that will allow for 3 hours of video to fit on a disc. You already have the specs for a 3-hour disc (or you can use the aforementioned bitrate calculator to figure it out), so use those numbers.
There shouldn't be any confusion here. You're over-thinking things again. Stop it.
__________________
02-25-2010, 01:09 PM
If I'm shooting to get between let's say 5-8 or 10 matches on 1 dvd...what bitrate should I use in MC to get the max best picture I can..because I know each clip will have to be encoded with a low bitrate
02-25-2010, 03:03 PM
bitrate x length = size of video
4.37GB = max size on a single layer DVD
"good quality" = adequate amount of bits for the resolution
Chart shown at bottom of http://www.digitalfaq.com/guides/vid...rd-capture.htm
Input variables, solve for x
There's nothing I can help with here.
__________________
Best RW CDs and DVDs Bill Downing Blank Media 3 01-13-2011 01:15 PM
Which (Brand) of DL dvds is the best? DAN_D Blank Media 10 03-01-2008 09:01 PM
HD-TVs, DVD Recorders, Blu-Ray and HD-DVDs???? MOTUfan Home Entertainment and Videography 30 03-19-2006 02:36 PM
DVDS skips aisle3 Home Entertainment and Videography 4 10-29-2005 10:57 AM
What brand are my DVDs? jenstewart Blank Media 5 09-23-2005 02:30 AM
All times are GMT -5. The time now is 03:52 PM  —  vBulletin Copyright © 2011 Jelsoft Enterprises Ltd  —  SEO by vBSEO
