12-09-2009, 06:07 PM
from e-mail...
I installed Huffyuv and Premiere CS4 is not able to injest the video, only the sound. Please advise.
As proof of concept, install VirtualDub from here -- http://www.digitalfaq.com/forum/show...-pre-1727.html -- and then open the AVI file. See if that works.
If it does, then you can save a new AVI as an uncompressed YUY2 (YCrCb) AVI, and there won't be any loss in quality. It's not recompression, it's extraction to uncompressed format. Premiere CS4 should load that one just fine. Uncompressed video is 75GB/hour on average.
There is really no reason CS4 should have issues with HuffYUV. I don't have issues in CS3. Is this 64-bit OS? Maybe HuffYUV didn't install correctly?
Rebooting after install is also required, in many cases. Premiere and Windows can't see the new codec if they're already running.
Let me know how that goes.
If you don't mind, sign up in the forum, and we can continue the technical support issues here. Thanks!
03-02-2010, 12:00 AM
Also try a 64-bit built of ffdshow.
Those are available at http://sourceforge.net/projects/ffdshow-tryout/files/
For convenience, I've attached the latest version (2/26/2010).
Another option is to try the 64-bit version of HuffYUV aka HuffYUV64
Also attached.
VirtualDub with Filters Pre-loaded + HuffYUV [DOWNLOADS] lordsmurf Encode, Convert for discs 50 01-01-2024 09:54 PM
Premiere Elements, quick question on interlace dominance admin Edit Video, Audio 0 03-02-2009 05:17 AM
What version of HUFFYUV 777sp2 Encode, Convert for discs 5 10-06-2005 05:35 AM
Adobe Premiere 6.5 - good deal for boxed version ? jrnyhead Edit Video, Audio 1 08-05-2004 07:28 AM
ATI/Premiere file import problem jla314 Capture, Record, Transfer 21 08-04-2004 09:58 AM
