Open AC3 in SoundForge - quick trick!
If you have AC3filter installed in Windows, you'll notice that you still cannot open an AC3 file inside Sound Forge.
If you go to File > Properties, it will even confirm that the file is an AC3 Dolby Digital file. Wish I knew this a few years ago! :rolleyes: It won't be useful to everybody in every situation, but in certain workflows, this is a nice shortcut, to know you can open the AC3 without an initial re-encode to uncompressed WAV. May save you a step. |
Works! Very good.
For some reason same hack doesn't work for me.
I tried it with SF9e and SF10b(474). I used VDubMod 1.5.10.2 to Demux/Savewav (it's same procedure as VDubMod cant decode ac3->wav) so i get two files with .ac3 or .wav extension respectively which differ in few bytes (different hash). After i rename .ac3 by adding .wav to it but still neither of "".wav"" files cant be opened in SF (SF->File Open icon) [NOTE: An error occured while opening codec] and with ac3 file (before rename) [NOTE: The file could not be opened. Make sure the file exists and that you have access to file/folder] ac3->renamed to wav [NOTE: The file is in unsupported format]. Drag-n-drop is not supported in SF as it seems. Files are in 384kbit if that matters previously split into more files by VDM1.5.4.1 |
Is your AC3 two-channel (2/0) or six-channel (5/1) encoded? That may be the difference.
Also, newer versions of Sound Forge support AC3 Dolby Digital, so renaming the file may not be a good idea anymore, on these newer versions. You could always try to open it up in Goldwave, if you have that (and you should -- good audio program, very low-cost, good tool in your digital suitcase). Belight is another option. |
