04-16-2011, 03:19 AM
morsagmon morsagmon is offline
Hello.
I saved an MPEG file using the FF DownloadHelper plugin. The file plays perfect in Windows Media Player.
Importing it into Premiere 6.5 fails to render it properly. The video skips frames and slowly jitter from frame to frame (skipping frames) and there's no audio.
I installed the Adobe MPEG Encoder 1.3, to no avail.
The MPEG video has these attributes:
Total Duration: 0:47:40:21
Average Data Rate: 510.90KB per second
Image Size: 720 x 576
Pixel Depth: 0 bits
Pixel Aspect Ratio: 1.067
Frame Rate: 25.00 fps
Audio: 11025 Hz - 16 bit - Mono
Any ideas?
Thanks!
Mor
04-18-2011, 07:59 AM
A video that has been downloaded from the Internet is not likely in the uncompressed or lossless type of video format expected by a professional non-linear video editor (NLE) like Adobe Premiere. The older versions are even less friendly towards compressed formats.
You'll have to identifiy what sort of video/audio codecs are in use here. It's probably Flash On2 VP6, Windows Media (WMV), or H.264
There's a number of possible formats.
Use Gspot: http://www.digitalfaq.com/forum/vide...-analysis.html
Then convert it out to an uncompressed or lossless format (like Huffyuv), using something like Avidemux or VirtualDub.
All of that is freeware.
The following users thank admin for this useful post: morsagmon (04-20-2011)
mpeg, premiere 6.5
Conan O'Brian 'Lips' Video Editing Tutorial for Premiere lordsmurf Edit Video, Audio 1 03-31-2011 02:54 PM
Womble MPEG-VCR and MPEG Video Wizard [DOWNLOADS] lordsmurf Edit Video, Audio 0 12-27-2009 01:39 PM
Editing with Womble MPEG Video Wizard [VIDEO GUIDE] admin Edit Video, Audio 12 03-05-2009 10:39 AM
Stripping Audio from MPEG Tom_n_Jonna Edit Video, Audio 3 10-23-2005 09:45 AM
Audio editing using Womble MPEG Video Wiz jrnyhead Encode, Convert for discs 3 02-08-2004 12:40 PM
