Quantcast Help with Adobe Premiere and Huffyuv Files - digitalFAQ.com Support Forum
Go Back   digitalFAQ.com Support Forum > Digital Video > DVD Project Help > Edit Video & Audio
12-04-2011, 12:45 PM
jrodefeld jrodefeld is offline
Hello everyone,
I am having a serious problem with a project I am doing to transfer VHS tapes to DVDs. I have the files in huffyuv format. I have filtered and restored the video I am currently working on with both virtualdub and Adobe Premiere. However, my computer was crashing and giving errors, so I backed up my files to an external hard drive and reinstalled Windows. Now, I cannot open huffyuv formats in Adobe Premiere.
I need to use Adobe Premiere to edit these files. Actually, the files were created and joined IN Premiere before I reinstalled windows. Now I cannot get Adobe Premiere to recognize huffyuv files no matter what. I am using Premiere CS5.5. When I import the file, it is seen as audio only. When I import another type of file that is merely uncompressed, it works but I cannot output as huffyuv either. I am using Windows 7 x64. I installed the 64 bit version of huffyuv exactly as is mentioned on another thread, through the command prompt. I have no idea what to do to allow Premiere to import and export huffyuv files. It was working before I reinstalled Windows.
I also thought that I could simply load the file in virtualdub and export it as an uncompressed file and then open that in Premiere but Virtualdub gives an error message "avi index not found", etc and it won't open the whole file. Even if that DID work, dealing with uncompressed files would be difficult and undesirable.
Could you please help me to get Adobe Premiere CS5.5 to import and export huffyuv files? Thank you so much. I hope you can help me.
12-04-2011, 01:07 PM
What FourCC is coming up as on the files? You can check with GSpot. If you used the HuffYUV Multi-threaded patch to capture with, you need to install that codec as its a slightly different format with a FourCC of HYMT. Another trick you can use is to frameserve the file with Avisynth or VirtualDub to Premiere. Premiere will see uncompressed output that way since VDub or AVISynth is doing the decompression. Also keep in mind that if you are using 32-bit software, you need to install the 32-bit version of the codecs you are using.
12-04-2011, 01:50 PM
Originally Posted by jrodefeld View Post
However, my computer was crashing and giving errors, so I backed up my files to an external hard drive and reinstalled Windows. Now, I cannot open huffyuv formats in Adobe Premiere. ........ but Virtualdub gives an error message "avi index not found"
This honestly points to a corrupted file. Was your computer error related to bad spots on the hard drive, by chance? Did you figure out what the problem was?
And if it was a bad hard drive, then the problem still exists. At most, it's just temporarily hidden. Worst case is the bad spot was the location where important Windows files were stored, or other programs in use were stored. And when you moved files back to the main drive, the video is now stored on the bad spot. (Or are the video files still on the external drive? I'm not quite clear on source drive.)
There's a huge list of variables and potential problems at this point. You'll have to do some diligent process of elimination.
There's also several variations of Huffyuv:
  • Huffyuv,
  • Huffyuv (CCE hacked),
  • Huffyuv Multi-threaded (MT),
  • Huffyuv 64-bit
You must decode with the same version used to encode. Gspot will help with this, as the FourCC varies.
You can have MT version + one of the others installed side-by-side. (The others shared the same name: huffyuv.dll)
I'm leaning towards corrupted files. But I'd like to be wrong, so look at codec issues first.
You could also try accessing the files from another computer, to help eliminate local computer errors.
Where you always using Windows 7 64 bit?
__________________
If this site has been as helpful as a book or magazine, then Donate a few Dollars or Upgrade your Membership.
Adobe Premiere CS5 only $480.00 from Buy.com Kenneth M Video, TV - Coupons, Sales and Deals 1 02-17-2011 04:24 PM
Computer freezes with Adobe Premiere & Photoshop CS4 monks19 Computers 16 01-23-2011 03:16 PM
Huffyuv and Premiere CS4 is not working admin Edit Video & Audio 1 03-02-2010 12:00 AM
Wow, Adobe Premiere Pro CS4 support RMVB anllyy Web Streaming Video Help 2 01-17-2010 11:05 AM
Adobe Premiere 6.5 - good deal for boxed version ? jrnyhead Edit Video & Audio 1 08-05-2004 07:28 AM
All times are GMT -5. The time now is 04:03 PM  —  vBulletin Copyright © 2011 Jelsoft Enterprises Ltd  —  SEO by vBSEO
