01-16-2012, 03:09 AM
via Email or PM via Email or PM is offline
Regarding: How to Edit Video from DVD Recorder on a Computer (Windows)
I did not see the exact issue i have in the article above so here is the question:
I use a Sony DVD recorder GX-360 in VR Mode and STACK videos/old movies from TV onto a DVD-RW.
Sometimes my wife like a separate DVD to watch of just one old movie.
Is there software to EXTRACT just one video/movie so it can be recorded by itself on a DVD-R.
The VOB are broken into times and not Charters or videos.
Is there software you know that can read a VR Mode, read the MENU and EXTRACT the video into a PC file for recording.
It is the Extraction that I can not seem to figure out.
Thanks.
This question was asked via email. Site Staff no longer answer tech questions via email, so that others may read and benefit from our expertise. Please continue the conversation here. Either login or join as a Free Member, and we can continue troubleshooting your video, photo or web related issue. Thanks for understanding our tech Q&A policies.
01-16-2012, 03:14 AM
I'm afraid I don't understand the question entirely.
"VR mode" -- true VR mode, at least -- uses a single VRO file to hold the video. There is not a VOB set.
There's no way to extract content from a VRO file. It's simply copied from a disc to the computer, and then it can be edited in MPEG cut/splice/editing software, like Womble MPEG Video Wizard.
VOB files are part of the DVD-Video format, and are controlled by IFO files. Those should be broken down by recording, though I have seen a few DVD recorders that will merge all recordings if specs match (same "mode" -- meaning the same resolution and bitrate flags).
Your Sony recorder may be doing something funky and non-standard, so I doubt software exists to do what you want.
Editing in Vegas Pro 9, recommended storage space, typical times for rendering video? merchantord Edit Video, Audio 9 08-31-2010 06:27 PM
How to edit/convert DVR-MS files with Premiere Elements ? Kelly Edit Video, Audio 21 11-11-2007 01:30 AM
Broken mpeg2 fixer? manthing Edit Video, Audio 2 04-16-2006 07:42 AM
How to edit IFO/ISO/VOB files? mlaviolette Encode, Convert for discs 2 02-12-2005 08:25 AM
MMC Preset Times lantern Capture, Record, Transfer 2 08-05-2004 08:16 AM
