Quantcast Editing with Premier Elements 8 - use .MPG or .VOB files ? - digitalFAQ.com Support Forum
Go Back   digitalFAQ.com Support Forum > Digital Video > DVD Project Help > Edit Video & Audio
01-30-2012, 05:41 PM
scogdell scogdell is offline
Hi KP,
You converted a bunch of VHS tapes for me a couple of years back. Now that I have time, I’m actually going to start working with the files.
1. Using Premier Elements 8. Should I use the .mpg files or the .vbo files. I can import both types into the software. Which is better? I am going to do some minor quality editing…but will mostly make DVDs with menus, etc.
Thank you.
This question was asked via email. Site Staff no longer answer tech questions via email, so that others may read and benefit from our expertise. Please continue the conversation here. Either login or join as a Free Member, and we can continue troubleshooting your video, photo or web related issue. Thanks for understanding our tech Q&A policies.
01-30-2012, 06:43 PM
Site Staff / Owner and Editor
Hello again.
.MPG files = MPEG files in "raw" form (not authored to a format specification, such as DVD-Video or Blu-ray BDAV/BDMV).
.VOB files = MPEG files authored into DVD-Video format, which may contain non-video/audio navigation data, multiple audio streams, and subtitles streams, which can interfere with the precision and abilities of editing software. In the worst cases, video software will butcher the audio and video, because the DVD-Video format navigation packets confuse the software. DVD-Video is a distribution end-format, and editors generally don't handle distro formats very well. They're best suited to uncompressed or intermediary/mezzanine formats (which includes both MPEG-2 and lossless compression).
I realize that VOB description is pretty technical.
In short, use the MPEG-2 files when available.
Adobe Premiere Elements is, to my understanding, going to force a re-encode of MPEG video assets. That may result in quality loss, if all you're doing is cut/splice type editing (removing footage, re-arranging footage). A better choice would be an MPEG editor, such as Womble MPEG Video Wizard.
See these:
- Womble MPEG-VCR and MPEG Video Wizard [DOWNLOADS]
- Editing with Womble MPEG Video Wizard [VIDEO GUIDE]
- Womble MPEG Video Wizard DVD help/info [PREMIUM]
If you have any other questions, just ask.
Thanks.
__________________
- Thanks for visiting! | Advertise on The Digital FAQ | Upgrade to Premium Member
DV capture problems Adobe Elements 7 nigel Capture, Record, Transfer 1 10-24-2010 12:51 PM
Free $20 at Shutterfly, with Adobe Photoshop Elements (also on sale!), thru 11-9 admin Photography - Coupons, Sales and Deals 0 10-27-2009 04:47 AM
Premiere Elements, quick question on interlace dominance admin Edit Video & Audio 0 03-02-2009 05:17 AM
How to edit/convert DVR-MS files with Premiere Elements ? Kelly Edit Video & Audio 21 11-11-2007 01:30 AM
All times are GMT -5. The time now is 04:08 PM  —  vBulletin Copyright © 2011 Jelsoft Enterprises Ltd  —  SEO by vBSEO
