08-08-2012, 10:40 PM
Hi,
I started using VirtualDub for removing commercials from my Satellite recordings (captured in DV-AVI format using Canopus ADVC 110).
It works great for just cut & pasting, however I am not sure if it is frame-accurate like other NLE programs (such as Adobe Premiere) for cutting from DV-AVI sources (and Huffyuv AVI). Please confirm.
Regards
08-08-2012, 11:16 PM
It is frame accurate for uncompressed AVI, lossless AVI ( Huffyuv et al), and DV AVI formats.
Tip: Stream copy, don't full process.
naripeddi (08-16-2012)
08-08-2012, 11:29 PM
Thanks kp.
I am removing commercials, and then frameserving the video to MPEG-2 encoder. Still it needs to be streamcopied (and not full process)?
regards
08-08-2012, 11:38 PM
If you're frameserving, it doesn't matter. The recipient of the frame serve will obviously be re-encoding it.
Out of curiosity, which encoder are you serving out to?
08-09-2012, 02:24 AM
Thanks.
Well, I am still trying to get this HcEnc to work for frameserving. That is what I am using (trying to use).
Regards
08-13-2012, 11:23 PM
You can also try to frameserve into Avidemux and encode MPEG out from there. (I've never tried this, but it's something I would try, if the need arose. Just wanted to mention that option for you.) Some GUIs are easier than others. I often skip frameserving, because the process can go faster by encoding first to Huffyuv, then encoding next to two-pass MPEG-2 in MainConcept (or a free or lower-cost alternative). I have plenty of HDD space.
08-14-2012, 06:01 AM
Thanks LS.
Is Avidemux better encoder than Hc? Does it produce better quality?
08-15-2012, 03:51 AM
I don't know that the image quality will be any better or worse.
It's mostly just a GUI difference. The freeware MPEG-2 encoders all act pretty much the same now.
Increases in quality come by using professional MPEG encoders, such as MainConcept Reference, or even the Adobe Media Encoder.
08-16-2012, 03:14 AM
Thanks LS.
