07-07-2005, 02:23 PM
battle7 battle7 is offline
Send a message via Yahoo to battle7
Is there anyway to stitch MPEG segments together to make a long movie?
07-07-2005, 03:42 PM
markatisu markatisu is offline
yes, if you have a few mpgs you can either join them together in mpegvcr or tmpg, just be sure to check if they go out of sync. Or use decypter to rip the entire vob file out if its on a recorder disc then edit out commercials, parts you dont need and save as mpg
07-07-2005, 04:56 PM
File specs MUST MATCH. Same video (res, bitrate, VBR/CBR, etc), and same audio (MP2, AC3, bitrate, channels, etc).
Does not work otherwise.
07-07-2005, 06:29 PM
ha ha yeah that would help, I just figured that was self explanatory , oops
Converting a 12GB Mpeg to a 4GB Mpeg Konfusion Encode, Convert for discs 1 09-03-2007 06:06 AM
MPEG to AVI Question Tom_n_Jonna Encode, Convert for discs 2 12-02-2005 03:33 AM
MPEG-2 vs. MPEG-2 DVD in MMC TV Capture JimGorsline Capture, Record, Transfer 4 07-09-2004 02:20 AM
