Quantcast Deconstructing what QTGMC does to edges in progressive mode? - digitalFAQ Forum
10-01-2019, 10:31 AM
ELinder ELinder is offline
I've been trying to analyze what QTGMC is doing to edges when running in progressive mode, but I'm not making much progress. I like what it does to the fine edge noise, but not what it does to motion blur areas, but I'm struggling to figure out which plugins QTGMC is using to produce the effect that I like. Even when using "show settings" and going thru them one at a time to isolate the effects, I'm not making much headway since I'm thinking it's a combination of the masks and functions.
In particular, note the area around the letters on the microphone label. These are the raw clip, just IVTC, and IVTC+QTGMC.
AVISource("edges-clip.avi")
#ConvertToYV12()
tfm(order=1, mode=6, pp=6, field=1, slow=2)
TDecimate()
# InpuType=progressive source
#QTGMC(preset="slower", TR0=2, InputType=1)
11-14-2019, 12:36 AM
Remember that QTGMC also involves some NR.
I'm also not fond of slower, it enables too much, often results in softer output.
11-14-2019, 01:04 PM
Yes, I narrowed down what I was seeing to noise reduction along edges. However, I don't know enough about how the masking works to confine it to just edges and leave larger areas and motion blurred areas unchanged.
Erich
VHS to compressed format, crop the edges? Jayce72 Capture, Record, Transfer 14 06-24-2020 10:47 AM
Is SP MODE the Best DVD Recorder Mode? (NO!) lordsmurf Capture, Record, Transfer 4 04-14-2013 10:01 PM
Errors on the edges of converted VHS tapes? admin Capture, Record, Transfer 1 04-20-2012 01:24 AM
Panasonic FR mode or samsung 4 hr mode for vhs to dvd cyber-junkie Restore, Filter, Improve Quality 5 02-24-2010 10:29 PM
Encoding an XP (1 Hour Mode) MPEG to SP Mode shadowkaos Encode, Convert for discs 2 10-30-2007 09:29 AM
