12-30-2019, 12:56 AM
WarbirdVideos WarbirdVideos is offline
Is there a filter to correct for Y/C delay after an S-video capture to Virtualdub using Lagarith? I read that "flaxen" can do it, but flaxen is nowhere to be found.
Thanks,
Steve
12-30-2019, 01:53 AM
this avisynth script can do it :
avisource() # for interlaced source
assumetff()
separatefields()
A=Last
B=A.Greyscale()
Overlay(B,A,X=0,Y=-2,Mode="Chroma") # change values of X and Y according to your needs (Y=-2 is fine for vhs generally)
weave()
12-30-2019, 08:19 AM
The ChromaShiftSP is another simple option. As noted in the previous reply, if the source is interlaced you need to separate into fields before shifting chroma if altering in the y direction:
separatefields()
ChromaShiftSP(Y=-2)
weave()
12-30-2019, 10:11 AM
flaXen is in the pre-loaded VirtualDub download on this site.
But I'd probably still opt for Avisynth when available.
12-30-2019, 10:42 AM
Bogilein Bogilein is offline
ChromaShift V2.2.0 from JPSDR which is included in his filtres packet. Works in YUV color space.
Unzip and then put the Filtres_JPSDR.vdf file in your Virtual Dub plugin folder.
12-30-2019, 08:34 PM
Thanks Guys! Now I need to figure AviSynth and Virtualdub out.
y/c delay
Chroma delay on Laserdisc? metaleonid Restore, Filter, Improve Quality 34 03-27-2023 11:59 AM
Delay in video capture? Mazufa Computers 1 08-05-2019 05:01 AM
Audio Delay from Frame Synchronizer TBCs? Cingular Capture, Record, Transfer 14 06-02-2016 02:03 PM
JVC HR-S6800EG deck - 4H Delay Circuits Byteman Video Hardware Repair 3 02-09-2015 01:26 AM
Audio sync and video delay with TBCs Bertrandes General Discussion 12 06-23-2013 02:24 AM
