01-18-2020, 10:21 PM
Hi trying to find good ghost removal Filter or DCT ringing filter
i did test GhostBuster and LGhost avisynth filter i guess they where ok but to much detail was removed before the ghost or ringing was removed
i did test tmpgenc 2.5 ghost removal to but it was about the same as GhostBuster and LGhost
have anyone test this VirtualDub filter MSU Tuner TV Restore Filter http://www.compression.ru/video/tune.../index_en.html
it was from this forum i did find about the MSU Tuner TV Restore Filter http://www.dscalerproject.org/phpBB/...b44baa059a190a
here is a example what i mean
the movie is recorded from old analog tv signal about 25 years ago and it´s a old movie from 68 so the ghosting is only visible sometimes maby best to not do anything about it
01-20-2020, 06:44 AM
For the ghosting i don't know but for the noise reduction that's what you could use:
AVISource("E:\00-Montage\ghost.avi")
assumetff()
converttoyv12(interlaced=true)
separatefields()
#DeGrainMedian(limitY=0,limitUV=220,mode=3,norow=t rue,interlaced=true)
a=last
#clense(reduceflicker=false).merge(last,0.5).clens e(reduceflicker=false)
mot=removegrain(8,0).DepanEstimate(range=2)
take2=a.depaninterleave(mot,prev=2,next=2,subpixel =2)
clean1=take2.DeGrainMedian(limitY=255,limitUV=255, mode=5,norow=true,interlaced=false).selectevery(5, 2)
sup1 = clean1.minblur(1).removegrain(11,0)
\ .mt_lutxy(clean1,"x 1 + y < x 2 + x 1 - y > x 2 - y ? ?",U=2,V=2)
\ .msuper(pel=2,sharp=0)
sup2 = a.msuper(pel=2,levels=1,sharp=2)
###### Good mvtools values, Do not change, checked##########
bv22=sup1.manalyse(isb=true, truemotion=false,global=true,delta=2,blksize=16,ov erlap=8,search=5,searchparam=4,DCT=5)
bv21=sup1.manalyse(isb=true, truemotion=false,global=true,delta=1,blksize=16,ov erlap=8,search=5,searchparam=4,DCT=5)
fv21=sup1.manalyse(isb=false,truemotion=false,glob al=true,delta=1,blksize=16,overlap=8,search=5,sear chparam=4,DCT=5)
fv22=sup1.manalyse(isb=false,truemotion=false,glob al=true,delta=2,blksize=16,overlap=8,search=5,sear chparam=4,DCT=5)
interleave(a.mcompensate(sup2,fv22),a.mcompensate( sup2,fv21),a,a.mcompensate(sup2,bv21),a.mcompensat e(sup2,bv22))
mergeluma(TMedian2(),0.9).mergechroma(TMedian2(),1 ).selectevery(5,2)
sup3 = last.msuper(pel=2,sharp=2)
bv33=sup3.manalyse(isb=true, truemotion=false,global=true,delta=3,blksize=8,ove rlap=4,search=5,searchparam=4,DCT=5)
bv32=sup3.manalyse(isb=true, truemotion=false,global=true,delta=2,blksize=8,ove rlap=4,search=5,searchparam=4,DCT=5)
bv31=sup3.manalyse(isb=true, truemotion=false,global=true,delta=1,blksize=8,ove rlap=4,search=5,searchparam=4,DCT=5)
fv31=sup3.manalyse(isb=false,truemotion=false,glob al=true,delta=1,blksize=8,overlap=4,search=5,searc hparam=4,DCT=5)
fv32=sup3.manalyse(isb=false,truemotion=false,glob al=true,delta=2,blksize=8,overlap=4,search=5,searc hparam=4,DCT=5)
fv33=sup3.manalyse(isb=false,truemotion=false,glob al=true,delta=3,blksize=8,overlap=4,search=5,searc hparam=4,DCT=5)
last
weave()
function EdgeCleaner(clip c, float "strength", bool "rep", int "rmode", int "smode", bool "hot", bool "fix") {
strength = default(strength, 8.0)
rep = default(rep, true)
rmode = default(rmode, 17)
smode = default(smode, 0)
hot = default(hot, false)
fix = default(fix, true)
c = (c.isYV12()) ? c : c.ConvertToYV12()
strength = (smode==0) ? strength : strength+4
main = c.aWarpSharp(strength,1)
main = (rep) ? Repair(main,c,rmode) : main
mask = c.mt_edge("prewitt",4,32,4,32).mt_invert().mt_conv olution()
final = (!hot) ? mt_merge(c,main,mask) : Repair(mt_merge(c,main,mask),c,2)
final = (fix) ? Overlay(final,c.ConvertToRGB24().Crop(0,1,-c.width+1,-c.height+2),x=0,y=1) : final
final = (smode != 0) ? mt_merge(final,c,c.StarMask(smode)) : final
return final
function StarMask(clip c, int "mode") {
mode = default(mode, 1)
clean = (mode==1) ? c.RemoveGrain(17) : Repair(c.Deen("a3d",4,12,0),c,15).RemoveGrain(21)
diff = (mode==1) ? mt_makediff(c,clean) : NOP
final = (mode==1) ? diff.Greyscale().Levels(40,0.350,168,0,255).remove grain(7,-1).mt_edge("prewitt",4,16,4,16) : \
Subtract(mt_merge(clean,c,c.mt_edge("roberts",0,2, 0,2).mt_expand(mode=mt_circle(1)).mt_invert()),c). mt_edge("roberts",0,0,0,0).mt_deflate()
return final
function MinBlur(clip clp, int r, int "uv")
uv = default(uv,3)
uv2 = (uv==2) ? 1 : uv
rg4 = (uv==3) ? 4 : -1
rg11 = (uv==3) ? 11 : -1
rg20 = (uv==3) ? 20 : -1
medf = (uv==3) ? 1 : -200
RG11D = (r==0) ? mt_makediff(clp,clp.sbr(),U=uv2,V=uv2)
\ : (r==1) ? mt_makediff(clp,clp.removegrain(11,rg11),U=uv2,V=u v2)
\ : (r==2) ? mt_makediff(clp,clp.removegrain(11,rg11).removegra in(20,rg20),U=uv2,V=uv2)
\ : mt_makediff(clp,clp.removegrain(11,rg11).removegra in(20,rg20).removegrain(20,rg20),U=uv2,V=uv2)
RG4D = (r<=1) ? mt_makediff(clp,clp.removegrain(4,rg4),U=uv2,V=uv2 )
\ : (r==2) ? mt_makediff(clp,clp.medianblur(2,2*medf,2*medf),U= uv2,V=uv2)
\ : mt_makediff(clp,clp.medianblur(3,3*medf,3*medf),U= uv2,V=uv2)
DD = mt_lutxy(RG11D,RG4D,"x 128 - y 128 - * 0 < 128 x 128 - abs y 128 - abs < x y ? ?",U=uv2,V=uv2)
clp.mt_makediff(DD,U=uv,V=uv)
return(last)
# median of 5 clips from Helpers.avs by G-force
Function Median2(clip "input_1", clip "input_2", clip "input_3", clip "input_4", clip "input_5", string "chroma")
chroma = default(chroma,"process") #default is "process". Alternates: "copy first" or "copy second"
#MEDIAN(i1,i3,i5)
Interleave(input_1,input_3,input_5)
chroma == "process" ? Clense(reduceflicker=false) : Clense(reduceflicker=false,grey=true)
m1 = selectevery(3,1)
#MAX(MIN(i1,i3,i5),i2)
m2 = input_1.MT_Logic(input_3,"min",chroma=chroma).MT_L ogic(input_5,"min",chroma=chroma).MT_Logic(input_2 ,"max",chroma=chroma)
#MIN(MAX(i1,i3,i5),i4)
m3 = input_1.MT_Logic(input_3,"max",chroma=chroma).MT_L ogic(input_5,"max",chroma=chroma).MT_Logic(input_4 ,"min",chroma=chroma)
Interleave(m1,m2,m3)
selectevery(3,1)
chroma == "copy first" ? last.MergeChroma(input_1) : chroma == "copy second" ? last.MergeChroma(input_2) : last
ConverttoRGB32(matrix="rec601",interlaced=false)
LoadVirtualDubPlugin("C:\Program Files (x86)\VirtualDub\plugins\Camcorder_Color_Denoise_s se2.vdf", "CCD", 1)
CCD(7,1) # de 0 à 100 # Défaut =30 /
converttoyv12(matrix="rec601",interlaced=false)
Return(last)
function TMedian2(clip c) {
Median2( c.selectevery(1,-2), c.selectevery(1,-1), c, c.selectevery(1,1), c.selectevery(1,2) ) }
function RemoveDirt(clip input, int limit, bool _grey)
clensed=input.Clense(grey=_grey, cache=4)
alt=input.RemoveGrain(2)
return RestoreMotionBlocks(clensed,input,alternative=alt, pthreshold=6,cthreshold=8, gmthreshold=40,dist=3,dmode=2,debug=false,noise=li mit,noisy=4, grey=_grey)
# Alternative settings
# return RestoreMotionBlocks(clensed,input,alternative=alt, pthreshold=4,cthreshold=6, gmthreshold=40,dist=1,dmode=2,debug=false,noise=li mit,noisy=12,grey=_grey,show=true)
# return RestoreMotionBlocks(clensed,input,alternative=alt, pthreshold=6,cthreshold=8, gmthreshold=40,dist=3,tolerance= 12,dmode=2,debug=false,noise=limit,noisy=12,grey=_ grey,show=false)
The following users thank themaster1 for this useful post:
jjdd (01-20-2020)
01-20-2020, 07:24 AM
themaster1 Thanks
there are some errors in the code i guess something happened when you paste the code in the forum post
i did fix it there was many one space key errors
one more thing to get is Camcorder_Color_Denoise_s se2.vdf then maby it works
did find it from here http://acobw.narod.ru/
it looks very good Thanks again
01-20-2020, 08:42 AM
I see two echos of the edges. I don't know whether these were caused by the transmission, or if they are oversharpening halos from the playback VCR.
The black level of your clip is too high. Did you adjust it using Histogram in VirtualDub's Capture Mode without cropping "black" borders and head-switching noise? That would lead to this incorrect result.
Simple way that I know to reduce haloing is to downscale-upscale. You can choose the exact downscale width yourself; I just picked what looked good to me. The subtitles in your source have a higher resolution than the background video, which is a blurry old film print.
AVISource("ghost.avi").AssumeTFF()
# 'phase shift'
SeparateFields().Trim(1,0).Weave()
# downsize - upsize
Spline36Resize(330,height).nnedi3_rpow2(rfactor=2,cshift="lanczosresize",fwidth=width,fheight=height)
# black/white levels (brightness & contrast)
ConvertToYV24()
ColorYUV(off_y=-14,gain_y=14)
Source
Fix temporal field alignment; no more overt combing
Reduce halos
"Better" levels
DCT ringing is a technical term for a specific compression artifact found in JPEG, MPEG, DV, etc. It can never be present in video that was always analog & captured losslessly without a lossy compression step in between.
https://en.wikipedia.org/wiki/Ringing_artifacts#JPEG
https://kornel.ski/deringing/
Your sample is RGB32. A proper YUY2 lossless version of your clip is a little over 50MB instead of 90MB. When creating samples, use Direct Stream Copy mode in VirtualDub or Fast recompress if you need to change the compressor. The default Full processing mode converts to RGB, inflating the size and clamping values <16 & >235.
jjdd (01-20-2020),
sanlyn (01-27-2020)
01-20-2020, 09:02 AM
msgohan Thanks
im going to test this im a beginner when it comes to ghost removal
the ghosting is caused by the transmission that im sure of
themaster1 have you managed to run that denoise script on Avisynth+ 64bit
it does work very good with avisynth 32bit and i get about 5.5FPS
but i did try to get it to work with Avisynth+ 64bit it almost works and i get 23FPS
but there is something weird about depaninterleave when you run Avisynth+ 64bit
here is the modified code that i did get to work but not as good as the Avisynth 32 bit version
i had to add ConvertToYUY2 to depaninterleave and i have to take out selectevery(5,2)
so if someone know how to get it to work as good as with Avisynth 32bit that would be great
AssumeTFF()
separatefields()
a=last
take2=ConvertToYUY2(a,interlaced=false).depaninterleave(ConvertToYUY2(mot,interlaced=false),prev=2,next=2,subpixel =2)
clean1=take2.DeGrainMedian(limitY=255,limitUV=255, mode=5,norow=true,interlaced=false).selectevery(5, 2).converttoyv12()
bv22=sup1.manalyse(isb=true, truemotion=false,global=true,delta=2,blksize=16,overlap=8,search=5,searchparam=4,DCT=5)
bv21=sup1.manalyse(isb=true, truemotion=false,global=true,delta=1,blksize=16,overlap=8,search=5,searchparam=4,DCT=5)
fv21=sup1.manalyse(isb=false,truemotion=false,global=true,delta=1,blksize=16,overlap=8,search=5,searchparam=4,DCT=5)
fv22=sup1.manalyse(isb=false,truemotion=false,global=true,delta=2,blksize=16,overlap=8,search=5,searchparam=4,DCT=5)
y=interleave(a.mcompensate(sup2,fv22),a.mcompensate( sup2,fv21),a,a.mcompensate(sup2,bv21),a.mcompensate(sup2,bv22))
mergeluma(TMedian2(),0.9).mergechroma(TMedian2(),1 )#.selectevery(5,2)
bv33=sup3.manalyse(isb=true, truemotion=false,global=true,delta=3,blksize=8,overlap=4,search=5,searchparam=4,DCT=5)
bv32=sup3.manalyse(isb=true, truemotion=false,global=true,delta=2,blksize=8,overlap=4,search=5,searchparam=4,DCT=5)
bv31=sup3.manalyse(isb=true, truemotion=false,global=true,delta=1,blksize=8,overlap=4,search=5,searchparam=4,DCT=5)
fv31=sup3.manalyse(isb=false,truemotion=false,global=true,delta=1,blksize=8,overlap=4,search=5,searchparam=4,DCT=5)
fv32=sup3.manalyse(isb=false,truemotion=false,global=true,delta=2,blksize=8,overlap=4,search=5,searchparam=4,DCT=5)
fv33=sup3.manalyse(isb=false,truemotion=false,global=true,delta=3,blksize=8,overlap=4,search=5,searchparam=4,DCT=5)
last
weave()
return final
final = (mode==1) ? diff.Greyscale().Levels(40,0.350,168,0,255).removegrain(7,-1).mt_edge("prewitt",4,16,4,16) : \
return final
uv = default(uv,3)
\ : (r==1) ? mt_makediff(clp,clp.removegrain(11,rg11),U=uv2,V=uv2)
\ : (r==2) ? mt_makediff(clp,clp.removegrain(11,rg11).removegrain(20,rg20),U=uv2,V=uv2)
\ : mt_makediff(clp,clp.removegrain(11,rg11).removegrain(20,rg20).removegrain(20,rg20),U=uv2,V=uv2)
return(last)
#MEDIAN(i1,i3,i5)
m2 = input_1.MT_Logic(input_3,"min",chroma=chroma).MT_Logic(input_5,"min",chroma=chroma).MT_Logic(input_2 ,"max",chroma=chroma)
m3 = input_1.MT_Logic(input_3,"max",chroma=chroma).MT_Logic(input_5,"max",chroma=chroma).MT_Logic(input_4 ,"min",chroma=chroma)
selectevery(3,1)
LoadVirtualDubPlugin("C:\Program Files\VirtualDub64\plugins64\ccd_64bit.vdf", "CCD", 1)
Return(last)
return RestoreMotionBlocks(clensed,input,alternative=alt, pthreshold=6,cthreshold=8, gmthreshold=40,dist=3,dmode=2,debug=false,noise=limit,noisy=4, grey=_grey)
and i put my Avisynth+ 64bit Plugins here to that i did use to get it to work and the Virtualdub plugin ccd_64bit.vdf
i put an example how Avisynth 32bit does the denoise and how the Avisynth+ 64bit does it
you can see tru if something goes fast you see what i mean on the example
01-22-2020, 10:12 AM
I wanted to quickly mention that some of my most impressive de-ghosting work was actually done in TMPGEnc Plus 2.5, with some of the filters found in it. The chased it with Avisynth. So while Avisynth in the defacto tool for restoration, often followed by VirtualDub, remember that some other useful tools may exist.
I see you tried this, so kudos.
jjdd (01-22-2020)
01-22-2020, 10:18 AM
lordsmurf ok Thanks for the info i have to try it more
to be honest i didn't try it so much i did only give it one setting and done i was to lazy
01-22-2020, 10:28 AM
I never need the de-ghosting, aside from my nth gen hobby work, and haven't done any of that in years. I took care of my more difficult hobby projects in the late 2000s.
But I do vividly recall filter chains in TMPGEnc were like 8-12 filters long, sometimes using the same filter with a different preset in the chain. In hindsight, and after Avisynth advances, some of the NR would probably be better done in Avisynth now, but that'd be one heck of a back-and-forth between the programs, time consuming chain. But doable!
Good luck. Ghosting can be a harder error to chew through.
But again, I think the error on this thread is slight, not like the ghastly analog cable sources I was doing, recorded to VHS.
01-22-2020, 10:35 AM
ok
lordsmurf have you test MSU Tuner TV Restore Filter VirtualDub filter
i think it have ghost removal to but do not know how good or bad
01-22-2020, 10:50 AM
I've never liked anything from MSU. Something better always seems to exist.
01-22-2020, 11:38 AM
lordsmurf ok
01-22-2020, 11:58 AM
msgohan Thanks
I've never dared to try (only avisynth 2.6 MT), i guess it's time if i consider the fps increase.
Usually i use SetMemoryMax(1200).SetMTMode(3,4) but it's a funky experience (some filters like that other don't...) and then i find myself trying all combinations possible during 30min with avsmeter until it crash (or not). I hate avisynth deep inside me Arghhh
01-22-2020, 12:53 PM
themaster1 ok
i use this to avisynth 2.6 MT and i have similarly settings on the top of the script like you have SetMemoryMax(1920).SetMTMode(3,4)
the computer i use have i7-970 Processor and 12gig ram and Windows 7 64bit it´s maby 10 years old i did build it myself
but down on the script i i change SetMTMode to SetMTMode(5)"slower but more stabel" if there is unstable functions and change again to SetMTMode(2) or even SetMTMode(1) if does functions are more stable
i try to have SetMTMode as low as i can so i get more speed
and sometimes i use ImageWriter function to output image sequence if the script is slow and unstable then it does not matter if it crash you can just continue where it crashed
example of ImageWriter function it output image sequence as tiff
return last.ConvertToRGB24().imagewriter(file="D:\movie\image%d.tiff",start=0,end=0,type="tiff")
and to read the tiff image sequence example
ImageSource("D:\movie\image%d.tiff",start=0,end=99999,fps=25)
The following users thank jjdd for this useful post:
lordsmurf (01-22-2020)
01-22-2020, 01:02 PM
themaster1 ok
Interesting. I've saved these notes.
01-22-2020, 01:06 PM
lordsmurf
01-23-2020, 06:26 AM
Hi i was wrong about the speed Increase in Avisynth+ 64 bit sorry about that it did not do everything that Avisynth 32 bit did thats why it was faster
but i think i did manage to get it to work with Avisynth+ 64bit as good as with Avisynth 32bit but little slower :/
here is the Avisynth+ 64bit version
AssumeTFF()
separatefields()
a=last
#Interleave(temp.Repair(clp.TemporalSoften(1,255,255,25,2)),clp)
Interleave(last.selectevery(1,-2), last.selectevery(1,-1), last, last.selectevery(1,1), last.selectevery(1,2))
take2=DePanInterleave(ConvertToYUY2(last,interlaced=false),data=ConvertToYUY2(mot,interlaced=false),prev=0,next=0,subpixel =2)
clean1=take2.DeGrainMedian(limitY=255,limitUV=255, mode=5,norow=true,interlaced=false).selectevery(5,2).converttoyv12()
sup1 = clean1.minblur(1).removegrain(11,0).mt_lutxy(clean1,"x 1 + y < x 2 + x 1 - y > x 2 - y ? ?",U=2,V=2).msuper(pel=2,sharp=0)
mergeluma(TMedian2(),0.9).mergechroma(TMedian2(),1.0 ).selectevery(5,2)
last
weave()
mask = c.mt_edge("prewitt",4,32,4,32).mt_invert().mt_convolution()
return final
return final
uv = default(uv,3)
return(last)
#MEDIAN(i1,i3,i5)
selectevery(3,1)
Return(last)
# return RestoreMotionBlocks(clensed,input,alternative=alt, pthreshold=4,cthreshold=6, gmthreshold=40,dist=1,dmode=2,debug=false,noise=limit,noisy=12,grey=_grey,show=true)
# return RestoreMotionBlocks(clensed,input,alternative=alt, pthreshold=6,cthreshold=8, gmthreshold=40,dist=3,tolerance= 12,dmode=2,debug=false,noise=limit,noisy=12,grey=_grey,show=false)
light version here to Avisynth 32bit MT
block_size i have it on 16 but 8 and 4 works to but slower
SetMemoryMax(1920) #enable if you use MT mode
SetMTMode(2,4) #enable if you use MT mode
AssumeTFF()
separatefields()
a=last
block_size=16
block_over=block_size/2
bv22=sup1.manalyse(isb=true, truemotion=false,global=true,delta=2,blksize=block_size,overlap=block_over,search=5,searchparam=4,DCT=5)
bv21=sup1.manalyse(isb=true, truemotion=false,global=true,delta=1,blksize=block_size,overlap=block_over,search=5,searchparam=4,DCT=5)
fv21=sup1.manalyse(isb=false,truemotion=false,global=true,delta=1,blksize=block_size,overlap=block_over,search=5,searchparam=4,DCT=5)
fv22=sup1.manalyse(isb=false,truemotion=false,global=true,delta=2,blksize=block_size,overlap=block_over,search=5,searchparam=4,DCT=5)
return last.mergeluma(TMedian2(),0.9).mergechroma(TMedian2(),1 ).selectevery(5,2).Weave()
#MEDIAN(i1,i3,i5)
selectevery(3,1)
LoadVirtualDubPlugin("C:\Program Files (x86)\VirtualDub_1_9_11\plugins\ccd_32bit.vdf", "CCD", 1)
Return(last)
uv = default(uv,3)
return(last)
here is a Denoise script i have use much on Super 8 film it´s modified Videofred´s Script but it work ok for VHS to i think but it´s extremely slow only 1.6fps
LoadDll("C:\VIDEO BILDER S8/fftw3.dll") #change the path where you have the dll files
m=AVISource("D:\movie\bttf2_930.avi",audio=false).AssumeTFF().SeparateFields().ConvertToYV12(interlaced=true)
m1=m.SelectOdd().denoise()
m2=m.SelectEven().denoise()
m3=interleave(m2,m1).Weave()
return m3
function denoise(clip movie)
block_size=8
USM_sharp_ness=23 USM_radi_us=2
USM_sharp_ness1 = USM_sharp_ness
USM_sharp_ness2 = USM_sharp_ness+(USM_sharp_ness/2)
USM_sharp_ness3 = USM_sharp_ness*2
USM_radi_us1 = USM_radi_us
USM_radi_us2 = USM_radi_us-1
USM_radi_us3 = USM_radi_us2-1
cleaned=movie.unsharpmask(USM_sharp_ness1,USM_radi_us1,0).RemoveGrain(2).unsharpmask(USM_sharp_ness2,USM_radi_us2,0).RemoveGrain(2)
SetMTMode(5) #enable if you use MT mode
vectors= MVAnalyseMulti(cleaned,refframes=6, pel=2,truemotion=true, blksize=block_size ,blksizev=block_size, overlap=block_over,dct=0,idx=1,search=1,threads=12,prefetch=1)
t=MVDegrainMulti(cleaned,vectors, thSAD=450,thSADC=0,limit=15, SadMode=0, idx=2,plane=4,threads=12).unsharpmask(USM_sharp_ness3,USM_radi_us3,0)
b2=t.mgrain33().mgrain3().NonlinUSM(1.2,1.5,1.2,3.5)
b22=overlay(b2,movie,mask=b2.GaussianBlur(VarY=20),opacity=1.0,greymask=true,mode="blend",pc_range=true)
return b22
SetMTMode(1) #enable if you use MT mode
function mgrain3(clip last)
blksize_size=4
overlap_size=blksize_size/2
dct=0
tmotion=false
super= last.MSuper(pel=2)
bv1 = MAnalyse(super, isb = true, delta=1,truemotion=tmotion,blksize=blksize_size,overlap=overlap_size, dct=dct)
fv1 = MAnalyse(super, isb = false, delta=1,truemotion=tmotion,blksize=blksize_size,overlap=overlap_size, dct=dct)
bv2 = MAnalyse(super, isb = true, delta=2,truemotion=tmotion,blksize=blksize_size,overlap=overlap_size, dct=dct)
fv2 = MAnalyse(super, isb = false, delta=2,truemotion=tmotion,blksize=blksize_size,overlap=overlap_size, dct=dct)
bv3 = MAnalyse(super, isb = true, delta=3,truemotion=tmotion,blksize=blksize_size,overlap=overlap_size, dct=dct)
fv3 = MAnalyse(super, isb = false, delta=3,truemotion=tmotion,blksize=blksize_size,overlap=overlap_size, dct=dct)
l=last.MDegrain3(super, bv1,fv1,bv2,fv2,bv3,fv3,plane=4,thSAD=650,thSADC=100,limit=15)
return l
function mgrain33(clip last)
blksize_size=32
dct=0
tmotion=false
l=last.MDegrain3(super, bv1,fv1,bv2,fv2,bv3,fv3,plane=4,thSAD=500,thSADC=300,limit=15)
return l
function NonlinUSM(clip o, float "z", float "pow", float "str", float "rad", float "ldmp")
z = default(z, 6.0) # zero point
pow = default(pow, 1.6) # power
str = default(str, 1.0) # strength
rad = default(rad, 9.0) # radius for "gauss"
ldmp= default(ldmp, 0.001) # damping for verysmall differences
g = o.bicubicresize(round(o.width()/rad/4)*4,round(o.height()/rad/4)*4).bicubicresize(o.width(),o.height(),1,0)
mt_lutxy(o,g,"x x y - abs "+string(z)+" / 1 "+string(pow)+" / ^ "+string(z)+" * "+string(str)+
\ " * x y - 2 ^ x y - 2 ^ "+string(ldmp)+" + / * x y - x y - abs 0.001 + / * +",U=2,V=2)
return(last)
01-24-2020, 06:17 PM
i did test my old super 8mm film HDR avisynth scrip and did modified it little to test if i can use it somehow to overlay original clip to a clip i have done aggressive setting to removie ghosting
and it did works good maby Ghostbuster or LGhost avisynth plugin does not remove so much detail if i do the extream overlay thing that my HDR scrip does maby it does not need that many overlays maby just one it was many many hours trial and error when i did it for my Super 8mm film this HDR script but i did delete some lines of code which is not needed here
anyway i put it here
SetMemoryMax(512)
SetMTMode(2,4)
k_stab=AVISource("D:\movie\tpta4444.avi",audio=false).ConvertToYV12()
a_stab=k_stab
#b_stab=k_stab.ConvertToYuy2().ColorYUV(gain_y=-120,cont_y=0).Ghostbuster(offset=3,strength=95).ConvertToYV12()
b_stab=k_stab.ColorYUV(gain_y=-120,cont_y=0).LGhost(1,2,15,2,2,115,4,2,-127)
e=overlay(hhddrr01(a_stab,b_stab),hhddrro2(a_stab,b_stab),x=0,y=0,mask=hhddrr01(a_stab,b_stab),opacity=1.0,greymask=true,mode="Blend",pc_range=true)
return e
function hhddrro2(clip a_stab,clip b_stab)
t=a_stab
ab=overlay( b_stab,t,x=0,y=0,mask=b_stab,opacity=0.5,greymask=true,mode="Multiply",pc_range=true)
ab1=overlay(t,b_stab,x=0,y=0,mask=t,opacity=0.5,greymask=true,mode="hardlight",pc_range=true)
l=overlay(ab,ab1,x=0,y=0,mask=ab,opacity=1.0,greymask=true,mode="blend",pc_range=true)
last=overlay(l,t,x=0,y=0,mask=ab,opacity=1.0,greymask=true,mode="blend",pc_range=true)
return last.ColorYUV(off_y=0,gain_y=22)
function hhddrr01(clip a_stab,clip b_stabb)
b_stab=b_stabb
t=a_stab
ab=overlay( b_stab,t,x=0,y=0,mask=b_stab,opacity=0.4,greymask=true,mode="Multiply",pc_range=true)
abc=overlay( b_stab,t,x=0,y=0,mask=b_stab,opacity=1.0,greymask=true,mode="Difference",pc_range=true)
ass=overlay(ab,abc,x=0,y=0,mask=invert(ab),opacity=1.0,greymask=true,mode="Blend",pc_range=true)
ab1=overlay(t,ass,x=0,y=0,mask=t,opacity=0.15,greymask=true,mode="SoftLight",pc_range=true)
l=overlay(ass,ab1,x=0,y=0,mask=ass,opacity=1.0,greymask=true,mode="Blend",pc_range=true)
ll=overlay(ab1,ass,x=0,y=0,mask=ab1,opacity=1.0,greymask=true,mode="Darken",pc_range=true)
k=overlay(l,ll,x=0,y=0,mask=l,opacity=1.0,greymask=true,mode="Blend",pc_range=true)
return k
but the downsize - upsize method that msgohan did post have more details so it´s better to go with that
01-25-2020, 03:08 AM
Show us the results (before/after), a good deghosting script is always nice to have imo. In the past i've tried exorcist 'n stuff but wasn't satisfied.
01-25-2020, 06:31 AM
themaster1 ok here is a new Original_Test.avi clip and then GHOST_Removal_and_overlay_2_clips.avi and i put the avisynth scrip to that i did use
you can still see just little ghosting
i did add one more example clip it´s from the same movie
SetMemoryMax(512)
SetMTMode(2,4)
AVISource("D:\\Original_Test.avi",audio=false).AssumeTFF().ConvertToYV12()#.SeparateFields().Weave()
a_stab=Spline36Resize(330,height).nnedi3_rpow2(rfactor=2,cshift="lanczosresize",fwidth=width,fheight=height) # Clip 1 Original with light Ghost Removal
#b_stab=ConvertToYuy2().ColorYUV(gain_y=-170,cont_y=0).Ghostbuster(offset=3,strength=95).ConvertToYV12()
#b_stab=ColorYUV(gain_y=-120,cont_y=0).LGhost(1,2,15,2,2,115,4,2,-127)
#b_stab=ColorYUV(gain_y=-120,cont_y=0).LGhost(2,3,127,1,3,127)
b_stab=Spline36Resize(244,height).nnedi3_rpow2(rfactor=2,cshift="lanczosresize",fwidth=width,fheight=height) # Clip 2 More aggressively Ghost Removal
return e.ColorYUV(off_y=-4,gain_y=-7)#.AssumeFieldBased().Weave()#.ConvertToRGB32().imagewriter(file="D:\movie\image%d.tiff",start=0,end=0,type="tiff")
t=a_stab
b_stab=b_stabb
t=a_stab
return k
01-25-2020, 07:35 AM
You have forgotten an important detail at the beginning: ConvertToYV12(interlaced=true) otherwise it's considered progressive
