01-23-2020, 01:35 AM
WarbirdVideos WarbirdVideos is offline
Question:
I have video that's 720 x 480. I then crop the frame to eliminate the head switching at the bottom of the frame and the black borders. So now the frame is 708 x 470 (pixels). I output the video at 720 x 480 which increases the size.
So the question is - how are the missing pixels added back in, or are they? Is there interpolation taking place? There must be some quality loss, but is it proportionate to the pixels that were removed during cropping?
Thanks,
Steve
01-23-2020, 01:43 AM
Interpolation? Probably depends on software.
VirtualDub = no
Avisynth = no
Pixels are simply truncated, if frame size not set to resize. (Noting in VirtualDub, you resize to a 720x480 palette -- not the palette contents, which just re-centers on the colored/black background palette.)
708 = 12 pixels chopped off sides.
12 are added back to mask for 720. Basic math. 708+12=720
IMPORTANT: ALWAYS CROP BY 2 WHEN INTERLACED! Never odd numbers!
01-24-2020, 01:06 PM
josem84 josem84 is offline
You need to add black borders & re-center the frame after cropping. You will end up with your original 720x480 frame size. Doing it right, you'll keep the original AR intact and you won't degrade the image resizing it to something other than the original frame size.
Originally Posted by WarbirdVideos View Post
I have video that's 720 x 480. I then crop the frame to eliminate the head switching at the bottom of the frame and the black borders. So now the frame is 708 x 470 (pixels). I output the video at 720 x 480 which increases the size. So the question is - how are the missing pixels added back in, or are they? Is there interpolation taking place? There must be some quality loss, but is it proportionate to the pixels that were removed during cropping?
01-24-2020, 03:40 PM
So truncating views at a frame as an image rather than pixels?
Adding black borders back defeats the purpose of cropping them out. And if you render the video at the cropped settings (708x 472), quality suffers. I'm assuming that the frame size needs to be divisible by 16, and 708x 472 is not divisible by 16 - correct?
01-24-2020, 04:03 PM
Not at all... you're removing noise, which is the purpose of the cropping, and using solid black instead to fill the frame. You're safe with mod4 or larger.
01-24-2020, 05:33 PM
Great - thanks guys!
Steve
cropping
AVI to MP4 frame size, rectangle vs. square pixels? Ryelzz Encode, Convert for streaming 3 02-10-2021 09:19 PM
Cropping overscan from VHS (for DVD) naripeddi Edit Video, Audio 6 03-13-2013 03:17 AM
Slow Rendering with Video studio kabal2000 Encode, Convert for discs 5 09-04-2010 07:45 PM
Cropping with Free Transform and Canvas Size in Photoshop Canon Photo Processing, Scanning & Printing 1 03-20-2009 10:37 PM
Edit an mpeg without re-rendering dmsinger Encode, Convert for discs 4 03-16-2005 12:10 PM
