-   -   Audio Thumping Noise Coming Through Capture (https://www.digitalfaq.com/forum/video-restore/10455-audio-thumping-noise.html)
sublimesed 03-24-2020 08:23 AM
1 Attachment(s)
I'll admit, I don't have prosumer VCR (yet). I'm trying to determine where this audio thumping is coming from before I start spending a ton of money.
I don't seem to hear it if I connect the VCR to the TV using RCA cables, however that may just be the speakers on the TV? I've also cleaned all connectors on the VCR with Isopropyl Alcohol.
VCR
Brand: Symphonic
Model: SL2960
Output: RCA
Tape
Brand: Sony
Model: T-120VF
Capture Device
Brand: Pinnacle
Model: Dazzle DVC-100 v1.1
Input: RCA
Software
Version: 1.9.11
Video Codec: Lagarith Lossless
Audio Code: N/A
Audio Quality: PCM: 48000Hz, stereo, 16-bit
See Attached Video for the clip. Thanks in advance!
msgohan 03-25-2020 08:53 PM
1 Attachment(s)
Hmm. If you look at the Spectral Frequency Display, at the bottom there are little spikes with a repeating period of about 0.1 sec. I don't know the cause.
Attachment 11509
Is it specific to this tape? Try a retail Hollywood movie release.
sublimesed 03-26-2020 01:01 PM
Attachment 11509
Thanks for taking a look. It's been on every tape I've tried.
dpalomaki 03-27-2020 03:45 PM
FWIW: That low level motor-boating sort of sound I hear reminds me a bit of a low grade feedback loop I recall hearing years ago. It was a form of a relaxation oscillator.
sublimesed 03-30-2020 04:19 PM
Sorry, I'm not sure I follow this. Can you break this down in layman's terms?
Also, to add to this, I'm connected to a UPS however the outlet in this part of the house is not grounded. Could this be the feedback loop you are referring to?
dpalomaki 03-30-2020 05:30 PM
Be careful routing cables, long cables and parallel runs should be avoided as much as possible.
All devices should be connected to the same power strip. If using a camcorder as a player, try battery and then ac power to see if it makes a difference.
Eliminate all connections/cables that are not required for your process. e.g., if capturing s-video, do not connect the composite video jacks, do not connect anything to the VCR inputs, and so on.
Relaxation oscillations happen when a voltage somewhere in the system gradually increases silently, then reaches a point where it discharges creating the quick thump. The process repeats until resolved.
lordsmurf 03-30-2020 06:19 PM
Something else near the capture workflow is causing it. Maybe same room, same house/building, or even the local power grid.
Remember to put all devices on a UPS, not directly in the wall, not on some pathetic "surge protector". (All surge protectors are junk, regardless of price, promises/marketing, or how much you like it.)
These are nice units: https://www.amazon.com/CyberPower-CP...language=en_US
Beware of the cheapest units.
Bigger units worth the cost, but mostly just gives extra battery life.
sublimesed 03-31-2020 09:08 AM
Thanks for all of the tips. I have the VCR and Computer connected to a CyberPower CP1000AVRLCD.
I guess I'm going to try to move the VCR, capture device and PC further away from each other.
Thanks again. I'll report back.
sublimesed 04-08-2020 11:41 AM
This seems to have done the trick! I moved the VCR, Capture card and PC away from each other and I don't hear it anymore.
Thanks! (CASE CLOSED)
