Hi,
I am capturing Hi8/Video 8 tapes, lossless in
virtualdub 1.9.11.
Apart from a washed-out colour saturation (apparently a common issue with Sony DCR-TRV range) which I will correct post capture using filters etc, I am seeing two small issues with the capture quality:
1. I am getting lines at the bottom which are blurred horizontally (see picture) - is this head switching noise? or a dirty head? or just the way it is? As it’s in the overscan area, so I guess I can crop out but would be good if I could remove.
See Issue 1 attachment picture.
2. To the right of the picture, I am getting a vertical bar whereby the colours are distorted green/pink. What would be causing this?
See Issue 2 attachment picture.
Thank you.
