09-06-2020, 06:37 AM
Hello,
Some of the Tapes I have been capturing recently suffer from a yellowish bar on the right section of the video:
https://imgur.com/ZHXTwXt
Is this just noise? should I mask it out? or It actually can be fixed later on with Post-processing?
Thanks!
09-07-2020, 02:02 AM
That is not a yellow line, it is more of black and white edge due to lack of chroma, it is inherit to Video8/Hi8 recording systems.
Okiba (09-08-2020)
09-07-2020, 04:13 AM
Oh. Thanks for clearing it out. So It sounds like something I should be masking?
09-07-2020, 01:08 PM
You can crop horizontally in vdub to the limit of the active video area and resize to a legal H resolution, You can add both filters at the same time (crop filter first), However your aspect ratio will not be accurate since you are cutting beyond the 704 area.
Note: Do not crop vertically, just leave it at 480.
09-08-2020, 01:05 AM
Following Lordsmurf advice, I don't do any cropping to my videos. Instead - I mask during post-processing with VirtualDub. I wanted to know in general if I should be masking that issues - or there's a way to solve that post-processing and I should not mask it as it can be solved.
09-08-2020, 03:28 AM
In order for Site Staff to help, attach images to posts.
- Do not hotlink other sites.
- Do not link to "image hosting" sites.
09-08-2020, 03:35 AM
Attaching to the post. Thanks.
09-08-2020, 03:42 AM
That's just frame edge noise, and come from many things. For example, the optical edge, if this was a camera. But it could also be chroma/sharpening/etc artifacts, as mentioned.
Mask it, and move on.
09-08-2020, 03:56 AM
It was indeed a Camera. All footage I'm currently capturing is from my father old Video camera. Thanks again Lordsmurf :-)
