Avisynth F1Quiver() not working?
I've been on several sites this week, seeking Avisynth help from specific people, for various projects. Somebody here (themaster1) suggested that F1Quiver (http://avisynth.nl/index.php/FFTQuiver) could solve my current herringbone problem. He's mentioned it to other members here a number of times, most recently on a thread (http://www.digitalfaq.com/forum/vide...html#post54703) back in 2018.
Specifically, this was suggested to me: Code:
F1Quiver(last,"custom", 25, 100, 50, 35, 70,0, 80,90, 120,30,test =true,row = 155, erow=300,degree = 8,gamma =0.2 ) Alas, it's not working. Did anybody here ever try themaster1's script suggestions, and have it work for them? My script comes back with Code:
Script error: Invalid arguments to function 'F1Quiver'. Code:
AVISource("x.avi") I have both Avisynth 2.6 MT x86, and Avisynth+ x64 installed, and the DLLs are present in the accompanying plugin folders. This plugin is available for both, but neither work. Any idea what is wrong? FYI, this filter is a nightmare to use. Lack of useful documentation, no meaningful samples. I don't think anybody other than the author understands it, and I've never read where anybody has used it successfully. I've never seen a before/after clip, and cannot reproduce any useful results. For example, if you the script has the "degree" syntax, the error states that F1Quiver does not have an argument named "degree". If you remove degree, the error then starts that you must have the value "degree". It's a pretty f'd up script. The author's "examples" function, but it's not useful. No idea what's going on with those, zero documentation, zero samples to illustrate with those do. BTW, the original conversation was started at VH, hoping to get the attention of jagabo and johnmeyer (which it did), but neither of their solutions work. https://forum.videohelp.com/threads/...ngbone-removal |
Which version of it are you using? There are two different versions of it that have different ways of specifying the arguments, I've never gotten the newer one to work.
Older one linked here (2.5 version) is the one I have used. EDIT: Yeah, the test parameter is not on the newer one, that one has a separate function for it. Will have to test FQPlus for myself, seems it's been updated recently so maybe it works. |
If you have any success, let me know.
The reason for trying to use it was to reduce/remove herringbone noise. But I really have no faith in it working. The same author's previous FanFilter never worked for me, and now this doesn't either. I've never read where anybody has had any success with it to date. |
I've only really had success in using it for removing high-frequency noise like residual Y/C artifacts from composite capture of VHS tapes (via e.g my ES10) that weren't filtered out by the Y/C filter and similar herringbone noise caused by bad capacitors. That stuff is outside the bandwidth of the VHS tape though (usually low-pass filtered by VCRs at around 3 MHz for PAL, don't remember what it is for NTSC.) so it's straight forward to just apply a low-pass filter that removes everything above a certain point. I don't know if it would work as well for the video in the thread as there is a lot of actual video data in the same frequency band, even more so if the frequency of the interference is not uniform over the video.
3 Attachment(s)
I also tried F1Quiver--too many parameters and too few documentation. Could never really get anywhere with it.
I have had better luck with the Fan and F1QClean functions inside manyPlus. Both work, but in my experience the latter allows more latitude in detecting the signal to filter out, allowing less destruction. Because JPEGs uploaded here are downsampled, LS recommended that I attach a zip file with the various screenshots of these functions being used. Attached are the unfiltered clip, after Fan, after F1QClean, after F1QClean and RemoveDirt, after F1QClean/RemoveDirt/FFT3DFilter, and after Fan/RemoveDirt/FFT3DFilter. Looking at the images, F1QClean actually removes less than Fan, but what it leaves behind can be removed by the two later functions. In the photos after F1QClean/RemoveDirt/FFT3DFilter versus Fan/RemoveDirt/FFT3DFilter, you can see that using Fan first affects the bridge of her nose and her left earring more than if F1QClean is used first. Here are the functions used (with progressive footage) Code:
Fan(last,edge=false,span=5,uv=true,plus=0.02,minus=0.02) With Fan, the higher the span, the stronger the effect but the greater chance of destroying detail. Plus and Minus control the strength within the span used. 0.01 is the strongest, because "Only data which are beyond these tolerances from average are modified" (http://www.avisynth.nl/users/vcmohan/manyPlus/Fan.html) With F1QClean, the higher the first value, the less destructive the filter. You should keep increasing the first number as high as possible where you still see that the interference is removed. Setting it low will remove the interference, but also destroy the image. The second value is the limit of frequencies (?) that you want to filter out. The goal is to reduce the distance between the first and second values as much as you can while achieving the desired effect. Again, set span as low as possible to remove the interference. Hopes this helps! Unfiltered Attachment 16441 After F1QClean/RemoveDirt/FFT3DFilter Attachment 16442 |
you got lots of chroma noise and chroma shift to begin with. If you can upload a video sample i'll try to see what f1quiver can do
1 Attachment(s)
Thanks. Any tips are appreciated.
1 Attachment(s)
Also, while you are at it, if you have any suggestions for the noise in the attached clip it would also be appreciated. I tried to reduce it with RemoveDirt and SpotLess, which helped a bit. (SpotLess seemed to work better than vsCnr2).
1 Attachment(s)
v=LWLibavVideoSource(source="test.mp4",format="yv12") |
Thanks for the code. I was able to skip the mask by increasing the strength of DeStripe. CCD worked great. I guess you don't have qualms about converting to RGB like Sanlyn did...
I assume F1Quiver didn't work here, since it wasn't used? And where can you find SpotLessUV()? Is it the same as SpotLess? I can't find it anywhere.... |
yeah it's spotless basically one of the later versions the dev optimized for UV processing
1 Attachment(s)
Thanks. Do you have any tips for this ghosting issue above the woman's head?
Attachment 16460 |
