06-03-2020, 10:01 AM
sublimesed sublimesed is offline
I have successfully converted 4 other tapes using this Camcorder, so I'm wondering if these can be salvaged or if the heads need to be cleaned after a bad tape? Theses tapes were originally recorded on this camcorder.
The output from the LCD screen on the camcorder is the same as the capture via Firewire.
Camcorder
Brand: Sony
Model: DCR-TRV140
Output: Firewire
Tape
Brand: Sony
Model: Hi8 MP 8mm Video Cassette
See attached video for a clip of what it's doing. It wouldn't play in WMP, but it works in VLC.
06-11-2020, 02:50 PM
Did you try the basic troubleshooting already? Clean the heads, clean the cable contacts, change the firewire cable, rewind the tape to relieve excessive tension, You should have done all this before you even start the thread.
06-11-2020, 06:51 PM
Do the 4 tapes that previously ingested OK now show similar issues. If so it is likely dirty heads. If they still play OK it may be a flaw in the tape.
After cleaning the heads, if the problem persists, try connected the analog output (s-video or composite) to a TV set? Do you still see the problems? If not error correction in the player may be patching it for the analog output and you could capture that stream. (Typically the firewire data stream does not have error correction.)
The following users thank dpalomaki for this useful post: lordsmurf (02-01-2021)
01-19-2021, 01:02 PM
This is what I was looking for! Thanks, I will try that and report back.
It is working properly via S-Video and Audio Cables. Thanks!
No video/audio from Video8/Hi8 tapes, but Digital8 tapes work? mark_l Capture, Record, Transfer 0 12-03-2019 11:06 PM
Will GV-D200 capture/digitise Hi8 Digital8 tapes in Premiere Pro? Kiwi921 Videography: Cameras, TVs and Players 2 12-13-2017 06:31 PM
Digital8 TRV480 vs GV-D800 audio sync issues nesburf Capture, Record, Transfer 0 11-16-2016 09:05 AM
Digital8 Camera won't play digital 8 video tapes? DeeSeven Videography: Cameras, TVs and Players 10 07-31-2014 11:04 AM
Hi8 vs Digital8 Sony camcorder for playback of tapes? via Email or PM Project Planning, Workflows 4 11-23-2013 03:11 PM
