08-22-2021, 07:10 PM
This is the problem when manufacturers recycle model numbers. There are infinite letter and number combos to be had, so seriously, WTF?
The Panasonic DMR-E50 is apparently such an item.
The first Panasonic DVD recorders, the E series, had many flaws, and no TBCs of any kind (weak or strong). And yet, in some European countries, it's being reported that an E50 (and now E55?) is good. Maybe. Those reports are mixed, which is common with shared model numbers (or production changes). Or with low-end gear, mixed comments are just clueless vs. not clueless -- but I don't think that's the issue here.
Bogilein and I disagree on things, but I don't think he's blind to quality. We may not have the same definitions and expectations of TBCs, however. Not sure.
For now, I'll continue to discourage the use of E series. I don't like wishy-washy maybe/maybe-not nature of variable gear, and potentially bad recommendations that always ensue. I want to provide known quality video solutions, not encourage video gear gambling.
Originally Posted by Bogilein
Is it possible to upload a photo of the in-image tearing or a link where you can see it? So I can imagine what it looks like, maybe I know it under different name in my native language.
I have several good clips of this errors, but will (1st) have to find those, and (2nd) need some free time.
I'll circle back to you on this at some point.
08-22-2021, 08:46 PM
The recording on the video cassette is a ... generation recording. Played from a Hitachi SVHS Recorder without a line TBC. The first TBC in the recording chain is important, and in this case it is the DVD recorder, otherwise it would not be able to demonstrate its special capabilities.
The samples from the Hauppauge & Diamond were intended to show why a TBC(...ish) is needed for capturing. Since many people don't seem to know what a DVD recorder does in pass-through mode.
The Hauppauge USB2 and the Diamond 500 are often recommended. Without TBC in whatever form, it won't work.
It is always claimed that only the two Pansonic DMR ES10, ES15 have this special function for capturing analogue devices. The HS2 & E55 are older than the ES10, ES15.
It was only a small section of the recording, but the Blaupunkt/Panasonic SVHS VCR with TBC isn't the best choice for this recording.
I would have to do a test with a JVC SVHS VCR (with line TBC) & external frame TBC. I seem to remember that the result was not satisfactory either.
You can't compare the recordings directly because I used different capture cards (Canopus NX, Terratec AV Grabster 350, Pinnacle 500 USB) and therefore the levels are different depending on how they were set when I recorded. I corrected them slightly to push them into the safe range between 16-235. But this had no effect on the jitter correction.
If you want to make a proper comparison of different DVD recorders, all the recordings should be made with the same player and the same capture card. Probably best with one of the Ati AIWs, then the Lord would also be satisfied. Maybe I will find the time to do something like that.
It is best to switch off the line TBC of the video recorder when using the Canopus NX. If you have very bad recordings, like here, you have to use a DVD recorder that has better jitter correction.
However, it is the only capture card I know of that you can record without line TBC VCR and/or external frame TBC with satisfactory/good results without sync problems with the audio part and satisfactory jitter correction.
Originally Posted by themaster1
Amongst other bad things that i recall:
wrong video levels, tbc ok but not extraodinary, 704x480,576 recordings instead of the more common 720x480,576, old school OS menu
You better put your money on a Sony RDR HXD 870 -> 1070 (or anything in between)
You should take a look at the example with the Sony RDR HX680.
Some comments on the Sony RDR HX680. This is one of the successor models to the Sony RDR HX870 mentioned by themaster1. Nothing has changed there. I can also upload an example with the Sony 870 (which I also own). But it has the same result as the 680 or the identical Pioneer DVD recorders.
The Sony/Pioneer also only output the signal via the analogue outputs in 720x480/576i. You would have to use the HDMI output to record in 720x576i/480i. The video levels do not change whether I use the Panasonic HS2, E55, ES10, ES15, EH495, EX77.
Whether the TBC(ish) of the Sony is now better than that of the Panasonic is something everyone should make up their own mind about.
Old school OS menu really shouldn't matter now for a device that you just pass the signal through.
In my opinion, anyone who seriously wants to capture should have a DVD-Recorder as an alternative. It doesn't matter whether he uses an SVHS with line TBC and/or external frame TBC.
What is always forgotten with all the recommendations about which hardware to use is that you should choose the hardware according to the source.
With this tape, it is a DVD recorder that delivers the best result. For the next tape, maybe a line TBC VCR with external frame TBC or the Canopus NX or another DVD recorder, let's see....
Update because I see the Lord has comment something during the time I wrote.
Perhaps I should add that all my tests were done with PAL equipment. As you can read from the reports of experienced users here and on videohelp, there are differences between PAL and NTSC devices. Not only because of the Scart connector. But this is often mixed up when talking about the corresponding hardware.
Those who claim that the E55 & HS2 do not have jitter correction like the line TBCs of various vcr's devices should perhaps put on their glasses.
This was only one test. In order to have an exact overview, other test tapes would of course have to be used.
But I am also sure that I have various cassettes with which I can your recommended devices bring to their knees.
There should be a discussion about what a TBC should actually do. I'm sure I don't know all the errors that may occur at some point during the capturing process.
The following users thank Bogilein for this useful post:
Hushpower (08-22-2021),
lollo2 (08-23-2021),
msgohan (08-23-2021)
08-23-2021, 03:20 AM
i did most of my tests in ntsc for the E55 (despite i'm in france and dealling with pal/secam).
I'm telling you the E55 is a flop 10$ garbage equipment period
The sony rdr hxd series has more options like proc amps, slicker menu hdmi/component out, 15mbps mpeg2 recordings on hdd etc...
The following users thank themaster1 for this useful post:
lordsmurf (08-23-2021)
08-23-2021, 04:33 AM
I agree. You know I love Hauppauge USB Live-2, but it needs tapes in good shape AND a S-VHS with line TBC, or a high-end VCR without lineTBC and a DVD recorder in pass-through mode. (on the other hand lordsmurf always says S-VHS with lineTBC and frameTBC in the chain, to be able to face any problematic tape, so you and him agree!)
I was also considering to add a Canopux NX to my material (msgohan/brad user had one for sale) after checking his captures on videhelp forum and reading the positive reviews on the doom9 german forum, but its contraints scared me a little: Edius required, disable S-VHS lineTBC, uncompressed capture format, capture splitted through several files...
When talking about restoration, I always suggest to do a lot of experiments on own videos and never blindly follow a general guideline.
For the capture hardware it should be the same, as you suggest, but the problem is that not everybody own a lot of material like you and lordsmurf and other respectable users. That's why we need advices, and samples!, from the capture experts (you, lordsmurf, msgohan, latreche34, ...), and that's why I say thanks for sharing!
The following users thank lollo2 for this useful post:
08-23-2021, 04:51 AM
Eh...
There's a general baseline for restoring certain formats, in regards to removing the reparable flaws of the format. For example, all VHS has chroma issues, be it bleed/offset, noise, or both. So cNR (chroma NR, remove red/blue misty muck), probably some offset/bleed fixes. Usually light NR/degrain. Masking the overscan (head-switching, etc). VHS audio generally has some % of hiss.
But after those minimums, it skews in many directions. Or not at all, the tape has minimal issues.
And that's just the Avisynth/ VirtualDub restoring, not the baseline hardware (aka TBCs).
08-23-2021, 05:16 AM
I think it's wise to have a basic level of corrections, it's fun to experiment (I've personally had some extraordinary results), and sometimes changing the order of operations for certain tapes helps.
Nothing wrong with experimenting, but there are some things which are baseline restoration points as LordSmurf has pointed out.
08-23-2021, 05:34 AM
Yes, I agree with both of you, my statement was not clear!
A basic guideline is required at the beginning, to understand what to do. I personally followed sanlyn here and jagabo on videohelp to learn at the beginning.
But I have seen over the years many users blindly applying filters on their videos, and the results were not good.
There are so many AviSynth filters, in various order to be placed because they interfere each other, and each of them has so many parameters that you have to experiment on your own videos.
While my first restoration attempts were not so bad, it took me a lot of time to fine tuning the scripts to my videos, and I tried all (yes, all) of the available spatial, temporal and spatial/temporal denoisers and all (yes, all) of the available sharpener. And for each of them several runs with different parameters.
Now the next frontier is the large set of AI models in VapourSynth (Selur is doing a remarkable effort to introduce them in Hybrid, an excellent piece of software that I do not use), and I hope they will be available in AviSynth as well. Again, lot of experimentation is required!
RobustReviews (08-23-2021)
08-23-2021, 05:53 AM
Ah that does happen in web chats, fair play.
I lean more toward GUI tools, although I do use Hybrid and find it a wonderful piece of software and I use it many times a day.
They're all "tools in the box" so to speak.
The following users thank RobustReviews for this useful post:
lollo2 (08-23-2021)
09-01-2021, 02:33 PM
Interesting answer, especially since you only tested the Panasonic E50. Now, does your opinion apply to all Panasonic DMR's (including ES10, ES15) or only specifically to the E50?
Did you do your tests with NTSC cassettes with a real NTSC video recorder or are we talking about PAL-60?
I don't see any advantage of the Sony here because of the menu or the possibility to create a 15mbps mpg2 file if I only want to use the device as a passthrough. The only advantage here would be the ProcAmp features. Unfortunately it fails with this cassette in the jitter correction.
The JVC's video recorders with TBC so praised by the Lord fail here also on whole line.I have tested an JVC HR-S7600, HR-S8960, Philips 1500 (JVC HR-S 8600/9600). An external TBC could also do nothing more.
Here again a comparison of a JVC HR-S7600 with a Panasonic HS860. Both with switched on TBC.
JVC7600TBConPinnacle500vsPan860TBConPinnacle500.mp4
Here is a comparison of a Panasonic HS2 vs Panasonic HS860(TBCon).
HitachiPanHS2vsPan860TBConPinnacle500.mp4
msgohan (09-01-2021)
