08-26-2021, 07:45 PM
thestarswitcher thestarswitcher is offline
So I've come to the realization that it's very important to retain the interlacing on the final encoded "restored master", and I feel having the final product as interlaced can serve lots of benefits for long term storage and playback. However, I am a very big fan of QTGMC not just for it's deinterlacing capabilities, but it's also a very gorgeous cleanup tool.
Is there any way to utilize the cleanup features of QTGMC without deinterlacing the material? My sources derive from either 50i/60i motion clips from VHS. Thanks in advance!
08-27-2021, 06:19 AM
lollo2 lollo2 is offline
Not really, QTGMC noise removal is part of the deinterlacing process and use the "basis" of motion compensation to achieve it while reconstructing the frame from the field.
However it may work somehow, you can try setting FPSDivisor=2 to force QTGMC to drop the second frame, but be prepared to some tendence to stutter on the single-rate output.
Report the results here if you try!
interlaced cleanup, qtgmc
Grainy SLP tapes cleanup tips? thestarswitcher Restore, Filter, Improve Quality 4 10-07-2019 05:44 PM
Capture interlaced, but how to to keep video interlaced when making DVDs? premiumcapture Encode, Convert for discs 11 12-21-2013 03:40 PM
Cleanup and detailing better in steps or at the same time? cyber-junkie Restore, Filter, Improve Quality 1 01-30-2010 03:39 PM
FOR.A brand TBC FA-800A, chroma cleanup? deter Restore, Filter, Improve Quality 2 01-15-2010 04:29 PM
Interlaced vs. non-interlaced artifacts? via Email or PM Capture, Record, Transfer 1 04-16-2009 05:37 PM
