Need a little help with this very poor quality VHS tape. I will tell you that this company (DiscoMixClub USA) released some very poor quality videos back in the early 90's some were recorded by people in the crowd some were just recorded by some pointless individuals who couldn't care less about quality. This one tape I have here is just over saturated with redness and much more it's just one pure bad quality video.
The other main issue here is that the tape is NTSC and I have used a Panasonic NV-FS200 machine, yes I know all the problems this will give me using a none dedicated NTSC machine but I forgot how bad this tape was.
Like I said this tape was recorded using a Panasonic NV-FS200 = Lite-On HD-A760GX connected via s-video/2 phono
I don't want to install any high end software just to try and make this any better it's only one video I need to do so I have installed vd2 something I haven't used in many years. I have tried a few times to get some good results but it's still not what I want. I have tried using different colour filters but the end result is either too dark or I get too much ghosting I just can't fathom what settings to use and I am usually good with sorting something simple like this out.
Now I have uploaded 2 test files one is 1 min 69mb in size the other is just over 6 min 462mb in size the format of these files are MPEG-PS and will play in any decent player. They are cut videos straight off the Lite-on machine, there is also quite a bit of noise on the bottom I haven't cropped them.
direct download links
test 69mb file
https://1fichier.com/?9anehgyh3izuujr6vzyz
test1 462mb file
https://1fichier.com/?we1smdrokv99k8vijhyk
Format : MPEG-PS
File size : 463 MiB
Duration : 6 min 32 s
Overall bit rate mode : Variable
Overall bit rate : 9 875 kb/s
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings : CustomMatrix / BVOP
Format settings, BVOP : Yes
Format settings, Matrix : Custom
Format settings, GOP : M=3, N=12
Format settings, picture structure : Frame
Bit rate mode : Variable
Bit rate : 9 450 kb/s
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 4:3
Frame rate : 25.000 FPS
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.911
Time code of first frame : 00:29:11:13
Time code source : Group of pictures header
GOP, Open/Closed : Closed
Stream size : 441 MiB (95%)
Audio
ID : 189 (0xBD)-128 (0x80)
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Muxing mode : DVD-Video
Bit rate mode : Constant
Bit rate : 256 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 31.250 FPS (1536 SPF)
Delay relative to video : -480 ms
Stream size : 12.0 MiB (3%)
Service kind : Complete Main
Can anyone have a look at this and see if you can get a decent natural looking video. If you can will you please tell me what settings in vd2 you used because I have given up at the moment lol
