Deinterlace a DVD lossy using QTGMC hybrid?
HI
Im trying to deinterlace a DVD lossy using QTGMC hybrid. Could someone explain what are the best settings. Im trying to preserve as much quality as possible. I hope to upscale it and transfer to blu-ray Is the quality better from doubled framerate or not? Any help would be greatly appreciated. |
Note for context: VideoHelp thread on same topic is currently on post #12; waiting on proper re-done sample so targeted advice can be offered.
If you want quality , you most likely want to use the lossless mode of qtgmc, thus the most basic:
Thank you its starting to make sense.
To OP: beware that lots of material on DVDs is coded interlaced but it is not. |
