Quantcast DataVideo TBC-1000 has grainy noise? - digitalFAQ.com Support Forum
Go Back   digitalFAQ.com Support Forum > Digital Video > DVD Project Help > Restore, Filter, Improve Quality
10-26-2009, 04:47 AM
I have a question regarding the TBC-1000 ........ Today I turned it on and there was a lot of noise in the picture.
What I have is a JVC HR-S9911 --> TBC-1000 --> SignVideo Proc Amp --> Toshiba DVD recorder. With this chain this morning (with just the blue screen on from the VCR), the blue screen shows what I can only describe as grainy noise. The blue screen looks "rough."
I then hooked the VCR directly to the DVD recorder: no noise. Hooked the JVC to the proc amp to the DVD recorder: no noise. Then subbed in my old Datavideo TBC-1000 (it has a slightly broken front input panel): no noise. With all these setups, the blue screen is perfectly smooth.
Therefore, the noise is coming from your Datavideo. But I can't figure out why, nor how to fix it, and so I thought I would pick your brain. Any idea?
Thanks.
Answering this here on the forum, because it's actually a pretty common problem. And not just on a TBC-1000, but TBC's and video gear in general.
What you're running into is a power-related issue.
I had a few TBC-1000's for quite a few years -- until 2006, when I moved. The new location caused vertical bars to travel horizontally acoss the screen -- completely power related. Being in a rush, I replaced them quickly with AVT-8710's, which had no such issues. I had work to do, could not delay any longer.
Had I spent more time, and had I known what I know now, simply changing out the AC adapter would have done the trick. I know the adapter how have, for obvious reason, works perfectly. However, you exact location may have electrical issues. For me, the issue was a voltage overage, a constant 126V+ on the meter. It was within allowable levels, but it's several volts above average. New construction, TVA, new lines, close to the power relay, etc --- I get juiced here.
Does the TBC-1000 have a fuse inside? I don't remember -- sometimes those are guilty, too! The Elite Video BVP4+ proc amp has that exact issue sometimes, noise from faulty fuse.
My current AVT-8710 in use this very minute has an issue identical to the TBC-1000 error you've run across. When this AVT-8710 heats up, or has been left on for too many hours, it can show that problem.
Other times, the AVT-8710 just "goes bonkers", and you have to unplug it for a few moments, then plug it back in. It forms a honeycomb-like grain noise, seen easiest on a blue screen from a JVC VCR.
Cleaning the connectors with a non-cotton swab and some alcohol sometimes helps too.
However, in yet another experience, I've found that the s-video and/or composite cables can be at fault -- especially if you're doing a "crossover" connection, where the TBC input is composite, and the output is s-video. You're best staying s-video or composite throughout, from VCR to digital capture/recording device. Consider regular wires, not the fancy "gold" ones, for tests. When you're convinced it works right, try the cables you think are best. Sometimes this thick and expensive brand-name cables are worse than the pathetic noodles they give away for free. Go figure.
Hope this helps.
__________________
- Did my advice help you? Then become a Premium Member or make a donation.
Datavideo TBC-1000 timebase corrector, like new, for sale [SOLD] lordsmurf Marketplace 3 08-13-2009 02:19 PM
Pre-processing audio in SoundForge for noise removal in Goldwave [GUIDE] admin Restore, Filter, Improve Quality 0 05-12-2009 10:03 PM
SignVideo Manuals PA-100 and DR-1000 [DOWNLOAD] admin Restore, Filter, Improve Quality 0 03-18-2009 05:26 AM
DataVideo 100 or 1000? Which TBC version? manthing Restore, Filter, Improve Quality 4 07-13-2005 03:54 AM
Hardware Setup / TBC-1000 (Suggestions) CaZeek Encode, Convert 3 11-27-2004 05:25 AM
All times are GMT -5. The time now is 04:26 PM  —  vBulletin Copyright © 2011 Jelsoft Enterprises Ltd  —  SEO by vBSEO
